Zer0
522
242
My average is about 30 mpg. If you really try you can do a 40 mpg run but not any urban runs.
bgb
600
316
So today I got a red flash screen with “LOW COOLANT” pop up. Bit concerning considering my old GTD had coolant issues..
No drip puddles etc. Haven’t digged around properly, anyone know if coolant has UV light sensor bits in it anymore?
Hoping that it’s an airlock, gone to the pub to let the car cool and unscrew the cap... fingers crossed!
Stephenator280
112
40
Gave the old pipes a scrum and polish
Before
And after
Alorjosh
159
70
East Anglia
I have that to, not huge drop on tank. Apparently it’s a “quirk” of my engine model
Reactions: bgb
Damo H
4,715
2,820
Car Length In Front
Check the level and top it up, these cars a re notorius for having air locks even from factory. Has exact same thing driving down through franc, panicked as thought it would be the dreaded water pump as I was on 10k miles from new. Topped it up when I got to my destination (thankfully I'd done 95% of the 1,000 mile drive). Then it never used any after that. Done 17k now.
Reactions: bgb
Damo H
4,715
2,820
Car Length In Front
Yesterday really...
So massive thanks again to the gents at VAG Manchester and Progressive Parts. Those people following my build thread know my car was under power at the Dyno day, so the car is visiting RacingLine in just over a week. So just to annoy me it pinged for a service.
They don’t normally do services at a weekend, but due to some other projects, @PP Mark agreed to fit me in and at short notice too. So got the Haldex done as well. Filter was not bad after 17k, considering other photos I’ve seen:
Thanks to also to @PP Gareth for the entertainment, and Tom for all the hard work on the car!
CupraNJ
110
40
Bristol
Yesterday really...
Excuse my ignorance, but what's the picture of?
What is a typical cost for the Haldex service and at what mileage should it be done? Thanks in advance.
Damo H
4,715
2,820
Car Length In Front
Worked it out. That's the pump filter.
It is, and dealers say they don’t need doing. Tuners say around 10k. I’ve seen pictures of ones a right mess, but the mechanic Tom thought I’d had it done at it last Service it was that clean. (It’s done 17k without being done)
bgb
600
316
@Damo H @Alorjosh so far good. Seems to just be an air lock! The level hasn't come back much more then just above min line so I shall top up and monitor.
I did read the Golf R engines had this trait from factory, hadn't seen it on the Cupra's. Hopefully that's all it is!
Stefan147
193
140
Athens Greece
Mine has asked for a coolant top up twice until now (18K km). The dealer found no leaks at the first service. I will keep an eye though cause we all know the water pump issues with most VAGs.
Reactions: bgb
Don1961
213
118
wow, that's a nice little touch. Where did you get the lights from and where did you connect them?
I used these.....
https://www.amazon.co.uk/gp/product/B0832L6JBB/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 and one of these.....
https://www.amazon.co.uk/gp/product/B078MFFK8S/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
but I would think any 12V LED would do. I ran cables to the left and right footwell lights to get the supply and the earth behind the panels at the ends of the dash. By getting supply from the footwell lights means that these dim with them.
Some cars have the one under the air con panel, but I couldn't find any part numbers
