VCDS Lock button for wing mirrors
gaza1994
49
15
31
Scottish Borders
garethjohnstone.co.uk
Hi all,
I don't know if this is possible, but I've heard of people being able to do it.
What i want is, when i press the lock button on my key, for the wing mirrors to fold in (i currently have to press it for 2-3 seconds after locking the car)
So, I have VCDS, and had a look around a few of the controllers (long coding + adaptions) but couldn't find anything obvious.
Help?! :)
Legojon
I only wanted a remap
5,313
2,745
Hi all,
Help?! :)
Did you use the long coding helper to step through the blocks? If it can be done through Carista, it'll be available through vcds as well.
On the MK2 it's in door electronics I think... not sure on the MK3.
Walone
1,675
487
Near Heathrow
Hi all,
Help?! :)
This is how I did mine,
Select 09 (Central Elect)
Select 16 (Authorization)
Enter Unlock Code 31347
Select 10 (Adaptation)
Choose (22) Access Control 2 Radio(Funk) Spiegelanklappung Mode.
(I have a feeling when I did mine it wasn't under (22) I think I had to scroll
down to find the description under a different number).
Change options as below,
Stored value = by convenience operation via remote control key.
New value = by look?(think this is meant to say lock) command via remote control key.
Then Do it!
gaza1994
49
15
31
Scottish Borders
Then Do it!
so exactly "by look?" with ?
Walone
1,675
487
Near Heathrow
