is there a possibility on dsg gearbox when ever I put it on P automatically have handbrake on and when I put it D or reverse automatically deactivate the handbrake?
Isn't that the default behaviour?
If you have the handbrake on, switch it to D, tap the gas and it will disengage the handbrake automatically as you set off
...personally, I rather do it myself, since I don't think it is good for the car.
Thanks Jaco2k
my main point was for the P to have automatic the handbrake on
I've got a 2016 184FR Technology, so it's got all the LED DRL's, auto lights, etc, and a MIB2 head unit. In the OBDeleven Apps there's one that I wanted to active called 'DRL settings in head unit'. When I go into it, it says that it's 'Not supported'. My friend has the same car but a 2015 with the MIB1, and it works fine. Is it worth doing it manually through the adaptations with the following:
On or Off daytime running lights (DRL) from the screen
This modification will add a new option in the menu of lights that allow us to activate or deactivate the daytime running lights (DRL) from the screen.
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Daytime Running Light
4 - Sub - Tagfahrlichtnur Aktivierung oder durch BAP Bedienfolge moeglich
5 - Change value to ON
Didn't fancy just trying it in-case it buggers something up!
Can anyone help me out? My auto wipers are always on as described in this post but the fix isn't available because the pictures are gone. I've trawled through this forum, Skoda forums and VW forums looking for a fix but this is the closest thing I've found. Does anyone know what the images were or can provide new ones of the code that's there? I've tried PMing the user but they've not repliedFirst of all do this modification in module 09
1 - Electronic control module 09-. Code (31347)
2 - Adaptation
3 - wiper
4 - Menuesteuerung konfortwischen HW
5 - Change value to On
Then you need to activate setting in 5F unit otherwise you can control it and wiper going to run all the time on AUTO
1 - Electronic control module 5F-.
2 - Adaptation
This two menu need to bit of adjustment
First modify section Function list BAP
After that go to other menu Vehicle menu operation
Red marked need to be change
After you have finished with this mod need to reboot unit hold down power button until you hear crack in speakers
And that's it
Within OBDeleven steering assistance, has anyone activated the driving profile switchover and changed it to Direct, controlled over threshold value?
There are many people all over the internet saying it affects throttle response.
If so, why is it located in the steering section?
Surely it should just affect the steering and not throttle.
I've got a DSG and I've had it activated for days, and noticed no difference. I've tried it in drive and in sport mode.
Agreed. This pisses me right off. When you stop it is linked to your intermittent wiper delay.
If I purchase this would it allow me to disable stop/start on 2019/20 Leon Cupra.
