Lozzy15
Retrofit Heated Fan Washer Jets - MK3 Leon
Lozzy15
Mods mods mods
577
391
Ilkeston, Derbyshire
Reactions: Maypack
Stuart Bunce
I’ve literally been searching for wiring diagrams for weeks for this retrofit! Thank You!
I’ll also be doing the level sensor which you’ve also written up. Did you buy a repair connector for the sensor with the wires already fitted as the pins look to be a different type to the ones documented.
Lozzy15
Mods mods mods
577
391
Glad the guides helped out. The level sensor I got hold of already had the electrical connector still attached. The part number for that particular connector is 1K0 973 202. I've attached a picture of how the end looks
Lozzy15
Mods mods mods
577
391
Stuart Bunce
Thanks for the guide Lozzy, seemed like such a good idea starting it yesterday afternoon when it was light coding it this morning so I can hopefully confirm the coding on a pre facelift for you!
Reactions: Lozzy15
Stuart Bunce
Thanks for the info! I'll add it and credit you in the guide. Managed the install all ok? The BCM is a pain to get out.
Yeah the install was no bother, did both of your guides at the same time. I found it simpler to just remove the connectors for the BCM in situ rather than removing the unit.
Nov 13, 2024
Hi all, finished the install today, went through the activation in vcds and the following fault was thrown up after rescan.
Can this be tested using a multimeter on the sockets that plug into the jets to confirm the wiring is functioning correctly to confirm the issue is the jets themselves and not the wiring? If so what setting wound I use on the multimeter. Thanks
LeylandVCDS
416
242
Leyland, Lancashire
Hmm, I have a bit of an issue with the idea of heated washer nozzles, which stems from my old Granada years ago - you're driving down the motorway in minus temperatures, and go to use your washers. The nozzles are heated, as is the fluid in the bottle on some models, (though the pipes between bottle and nozzles are not) so the washer fluid isn't frozen, and you get a spray of fluid on your screen.....which instantly freezes on your screen with the wiper sweeps and obscures your vision completely.
When I had the Granada, I ended up disconnecting them. I'd rather have frozen fluid that can't get onto a mucky screen than to have my vision obscured completely.
Oh, memories, my Granada Ghia - how I wish I still had that motor :cry:
Walone
1,634
462
Near Heathrow
I'll just take my chances on a good concentration of this;-
LeylandVCDS
416
242
Leyland, Lancashire
Very probably OK now, back then screenwash didn't protect down to those temperatures. Thoughts of old are difficult to unthink though, it scared the hell out of me losing all vision in the middle lane of a motorway overtaking a wagon.....Wonder what actual screen temperature would be at speed with a wind chill taken into account? :unsure:
