Deleted member 103408
On my old girl the light comes on every time I start the car telling me its low and whilst the warning goes of you get the yellow triangle being lit all the time and it shows you on the center screen.
Another penny pinching cut as the car got more into its stride I am afraid.
RUM4MO
7,975
1,067
South Scotland
If that car does have a low washer fluid warning system, maybe it has not been enabled in coding, or if you are not the original owner, the previous owner might have disabled it - my old 2000 VW Passat 4Motion came new to me without the washer low level warning coded correctly, same for the brake wear indicator - I found out about the missing washer fluid warning the hard way on a long road journey in terrible winter weather - VAG-COM sorted that out!
Damo H
4,715
2,820
Car Length In Front
I believe the low level indicator is only on cars with winter pack, ie headlight washers with the larger reservoir :(
Maypack
Apr 20, 2014
3,175
2,330
Gods Country - West Cumbria
I’ve got the winter pack and headlight washers but no light comes on when I start the car up. Strange!! I think I’ll have to do a little bit more OBDEleven checking to see if it has been coded out.
g_berserk
Smartass in training
Oct 15, 2014
164
24
Monterrey, Mexico
Finally found a decent wrap shop in my price range to do the roof of the car, and the bouns is that they go to your house, so no need to drive to the other side of the town to get this done
Also, did my brake calipers in teal with white Cupra logos since that's the theme I'm runing in this car
Gunslinger300
92
9
Glasgow
Saturday:
Spent all day prepping the paint work for a ceramic coating. As soon as I finished the coating it started raining :rolleyes: oh well will just give it another coat when it's dry again :)
Today:
Received the VW fan jet washers after seeing the pos ton here, took 5 mins to fit and such a big improvement.
Next:
Going to grab one of those metal foot rests :)
Any chance of a link for the fan jet washers please?
Scottrick
53
15
Northern Ireland
Saturday:
Today:
Next:
Where abouts did you get the fan jet washers? Seen a few but hesitant to buy incase they're no good.
MrJohn91
136
64
www.facebook.com
Successfully fitted my short shifter.... Absolutely awesome and well worth it.. Plus very easy to install for a novice.
Sent from my CLT-L09 using Tapatalk
Reactions: ray
