Also when did you last service the diverted valve.
They will start to leak after a while. You can buy a replacement seal and spring too.
Best option is to return to OEM valve which is good to about 400 brake. Only about 30 quid too.
Hope that helps a bit.
Badger5 Custom Map + TIP,
