Hi all,
I’ve had a 2019 cupra 290 DSG for about a month now. Mostly, i absolutely love it! The only issue i’ve come across is unpredictable wheel hop under acceleration. This only seems to happen from a standing start, any kind of rolling start and it never (touch wood!) happens.
The bugbear is it’s unpredictability. Sometimes i can go flat out and it wont happen, other times i can just pull away quickly but not flat out and it will wheel hop like crazy. Road surface or rain don’t seem to affect it either, it just seems random. Wheelspin is very minor, surprisingly hardly a problem at all, but the wheel hop is horrendous when it happens.
My question is do changing the settings of the car make any difference to this? If so, what are the best settings to use i.e DCC, diff lock, engine, ESP on sport or off etc. I always drive in cupra mode with ESP off but if changing the settings in individual mode can help i’ll happily change them. Also, is launch control worth using to make a clean getaway or is that a waste of time?
I also checked tyre pressures for the first time today, fronts were at 42, backs at 39 from factory so i’ve put them to 39 front 35 back as per the sticker in the car, not sure if this will make any difference though. When it comes to changing tyres, are there better ones than the stock continentals that will help reduce wheel hop? I know mitchelins are supposedly the best tyres but would they reduce the issue at all?
Im on a 2 year lease so don’t want to be doing any kind of modifications, i just wondered if there is a sweet spot with a mix of settings that can reduce the issue. If there isn’t ill just have to lose the lead right foot when at the lights!
Any advice is much appreciated!
Many thanks
Many thanks
