Seat Leon Cupra 2019 drifiting to the right
Jun 1, 2024
17
I have Seat leon Cupra 2019
The car pulls to the right. I did a
Wheel alignment
Recalibrated the steering
balanced the wheels
. Additionally, they performed a more advanced wheel balancing with a device that shows where the tire should be positioned relative to the wheel itself.
But there is still a pull to the right. Does anyone know what else it could be?
SuperV8
1,695
808
I had my full 4 wheel alignment 'done' when I changed my front wheel bearings - and had to have it re-done as the wheel was no longer straight.
Might be worth getting it checked?
As RUM4MO above - needs to be a full alignment (both axles) - not just a front axle toe adjustment.
Jun 1, 2024
17
When you say "wheel alignment" do you mean a front end tracking check/adjust or a full "4 wheel" alignment check/adjust?
Yes, of course.
I did a 4-wheel alignment, and after that, the car was pulling to the right. So I went back to them, and they tried to adjust it with the tie rods. There was a slight improvement, but after three attempts, it was still not enough. They said that we need to “relearn the steering wheel” using a computer.
But now the steering wheel is a little bit off to the right while driving straight. When the steering wheel is straight the car pulling ti the left a little bit and it’s easier ti turn the steering wheel to the right side the to the left side
I need to check if the car is still pulling to the right on the highway.
