Carista App
silles
517
89
Electric handbrake? This happens in my manual too, s**t myself the first time it happened. Must be a safety feature so you can’t fall out and run over yourself?
yeah, that, hate it. the machines are taking over, don't like that :D
StumpyLeon
33
Yeah I’ve just enabled it the other day, I think it’s on the beta version though so email them to get signed up.
ah thats good i will email them today, also am i able to stop the drl's dimming when i go to sidelight?
CHimself
11
I’ve seen some settings about DRL % levels but not too sure if that was when turning on sidelights etc.. soon as you get the Carista dongle plug it in and get the debug data and send it them takes a day or 2 to get invited to the beta after you’ve sent it them.
connorman73
22
9
Anyone know if it's possible to change the door light colours when you change the driving mode, say green in eco, blue in normal and red in sport, when I change modes they just stay the same colour. Not sure if its possible with app and I can't seem to find the setting If you can.
Feb 10, 2019
I have 2 errors that keep coming back. Any ideas how to fix?
Central electronics
Fault codes:
263442 Manufacturer-specific code
Infotainment system
Fault codes:
02571 Input for interior light dimmer
scuj1
75
13
Edinburgh, Scotland
Hopefully this helps, it's some screenshots of my current setup with working ambient light controls.
Thanks for this. I'd also lost the menu but have it back now plus the additional 3 colours!
scuj1
75
13
Edinburgh, Scotland
Same as I found. I haven't been able to change anything on the ambient lights. I tried to add additional colours but nothing happened.
If you copy the settings on post 305 then select the additional colours. Once saved turn off the ignition, lock, unlock, turn the ignition back on and they should be there.
pdid
30
Can someone point me in the direction for the Soundaktor menu?
It's in the customize menu them the bottom option which iirc is other. It's shown as a percentage.
I turned mine off today, it was the sole reason for buying the adaptor.
Cupra_2019
68
68
I now get the colours as an option on the screen but it doesn't change the door lights only the lights around the screen and digital dash.
Is this the same as yours?
scuj1
75
13
Edinburgh, Scotland
I don't have the digital dash, so it only affects the doors. Did you have the menu for the colours before? If they weren't there by default you might not have RGB leds in your doors. I may be wrong!
Cupra_2019
68
68
Yes I had the menu and approx 8 different colours that changed both the door led and lights on the digital dash so definitely RGB LEDs in the door. I can now choose two additional colours but it doesn't change the door LEDs just the lights on the dash.
Neil Francis
81
46
Cambridgeshire
Mine turned up today, turned down the fake sound noise and now Cupra mode is enjoyable. I couldn’t see much else to enable though as my Cupra 2019 had most of it enabled. Does the beta option give me much else? Tbh it was £16 well spent just for that one option.
Reactions: bigup and AlexOS
servicepoint
96
16
I’ve bought the Carista dongle but when I open the app it asks which version, Kiwi3 or WiFi, which one is it?
Got it, It’s the Wi-fi.
Reactions: Neil Francis
