It's to stop them freezing so you can use in the cold weather, then again there is nothing to stop the pipes freezing (unless you have the correct concentration of screen wash) or the water when its hits the windscreen!I just put fans on mine. It did have heated ones however I didn't know and bought the non heated ones. But they still work with no fault codes. I can't really tell the difference between heated and non heated in term of cleaning the screen to be honest!
Sent from my EML-L29 using Tapatalk
Without exaggerating, literally under 2 mins start to finish, with bare hands, at -2 outside.
Went back later with a tool to adjust up slightly.
Anyone else find the jets take a little longer to ‘fire’ than the pistols? Like it takes a half second for pressure to build at first?
aftyer fitting my fan washers i've had to adjust them fully up and still the water jet is hits the windscreen wiper arms. I can't remember if the pistols types did the same but I don't think so.
Maybe a reason why the Leon doesn't have the fan type fitted?
Yip fully up is the only way that suits the leon but it should be enough to cover the whole windscreen when at a standstill. Also did you buy genuine vag ones or the cheap Chinese replicas? This also makes a difference.aftyer fitting my fan washers i've had to adjust them fully up and still the water jet is hits the windscreen wiper arms. I can't remember if the pistols types did the same but I don't think so.
They’re genuine VAG ones bought from a breaker. They came off a Touran I believe. I might just be being paranoidYip fully up is the only way that suits the leon but it should be enough to cover the whole windscreen when at a standstill. Also did you buy genuine vag ones or the cheap Chinese replicas? This also makes a difference.
If you look back through the posts you will see we all had to move the fan type quite a way up on the out-the-packet setting.
All to do with the angle of the bonnet vs windscreen of the different VAG cars. If you are on full adjustment and still too low something is not right. Assuming you have gone the correct way...(you can see it move as you turn the adjuster)
As long as the whole w/screen gets a soak at a standstill convince yourself that your happy with it lolI noticed others commented on fully adjusted up on theirs which is the same as I have had to do. I think I was just confusing myself as the wipers were getting sprayed on when they were adjusted lower and then even when adjusted up the jet will hit the wipers once they start moving so probably turned into mind tricks. Will check again in the am with a fresh head...
Ye it’s easy to look at something for too long and convince yourself something ain’t rightAs long as the whole w/screen gets a soak at a standstill convince yourself that your happy with it lol
I might have to get some genuine ones, I also got some off ebay, they didn't fill the hole under the bonnet so they moved about and the spray was utter shite.I bought some cheap ones off eBay (£7) and they didn't fit.
So bought some genuine ones from Listers for £20.
