Haha definitely don't rape around the areas!!Okay cool. Where can I get some from? Do you just rape around the areas?
Oh dear, are we going to get some kind of #MeToo campaign going following this post :OOkay cool. Where can I get some from? Do you just rape around the areas?
Defo only software...https://www.onlyrevo.com/product-details/software/seat/leon-mk3-2012-/194/stage-3
£899 seems on the low side. Don't know if that's just the software? They also list the required hardware so you could compile a shopping list
Hardware about another £3.5K, assuming turbo exchange.
Note: There is no Stock mode due to stage3 vehicles not running standard components
Bloody autocorrect hahaHaha definitely don't rape around the areas!!
Okay chap cheers. Is it easy enough to do then would you say and do you have any pictures??I ordered mine from amazon. I’d recommend not doing as you say! But yeah I used a bin bag and cut it down one side and opened it up so it covers more and then taped it to the car and cut a square out in the middle where I was working on
Also, did you just get the black spray and buy just the one can?How do you use the plastidip? It just comes in an aerosol can and you clean the area you want to work on properly and give it lots of light coatings with 30 mins in between each layer
Is from acidic wheel cleaner / TFR (traffic film remover. A lot of car wash places use it.Noticed that my wheel nut covers have all gone white, guess maybe something to do with the car wash although this didn't happen with my last Leon, cleaned one and it now looks grey instead of black
Cheers, guessed that would be the case... they must be rubbish then only the 3rd or 4th time it's been washed since I got new at the end of OctoberIs from acidic wheel cleaner / TFR (traffic film remover. A lot of car wash places use it.
Is just a residue so appears quite quickly. You should be able to rub it off OK, but it can leave unpainted coloured plastics a bit faded as you have found.Cheers, guessed that would be the case... they must be rubbish then only the 3rd or 4th time it's been washed since I got new at the end of October
Off for a run to Chester with the missus.
