Yesterday I fitted a Forge dogbone insert (low engine mount in subframe) on my Cupra R 2018 310. No problems, it went well . Needed to take down the plastic under cover/engine shield to be able to adjust the engine to fit to the bolt. I noticed that the car have a whole cover /engine shield which is bolted in in front/sides and in the sub frame. 3Q0 825 236 C.
My former Golf R I had the half cover 3Q0 825 235 A. This shield leaves the plastic oil pan/sump fully visible when you bend down and look under the front.
Now to my question:
Could another owner of Cupra R limited edition bend down and take a look under the front and report back if you also have the "big" whole cover.
The Cupra R have a rather big front CF splitter which presses in much air via lower grill into the engine bay, therefore I’m considering to open up say 4x 30mm round holes to help the air to evacuate in the rear part of the under shield nearby the subframe since it's a "whole cover".
The one fitted in my Cupra R:
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/baffle/3q0825236c/
The one fitted in Golf 7 R and GTI. (I suppose also in Cupra 5F):
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/front-belly-pan/3q0825235a/
Grateful for your help.
/Peter
Now to my question:
/Peter
