a ZENEC TECHNICAL INFORMATION
SEAT Ibiza (type 6J) conversion to ZENEC Z-E5514M
1) Vehicles without seat heating ex works
Complaint:
Button for ESP and SET no function
Root cause:
For vehicles without seat heating ex works, the power supply to pin 17 is not available
Reading:
a) Use the ZENEC cable set (Art. Nr, Z-EACC-S6JN)
b) Modification of the existing cable set:
~ Pin pin 17 (white) out of the plug housing (A) on the vehicle side
- Connect the unplugged (white) cable Pin 17 with the soldering
(green) cable pin 16
ee orn aaa
ay ZENEC TECHNICAL INFORMATION
2) Vehicles without tire pressure control ex works
Complaint:
Various keys such as ESP and SET have no function
Root cause:
On vehicles without tire pressure control ex works the power supply is on pin 16 and pin 17
unavailable
Reading:
~ Add an additional lead from connector (E1 or E2) for ESP from pin 3
Plug B Pin 16 and 17.
3) Vehicles with start / stop shears ex works
Complaint:
When converting the touch bar in front of the shift lever, the start / stop button can not be integrated
become,
Root cause:
In the Vorfacelift Jahrgangen no scoreboard with start / stop was provided
Reading;:
Modification of the existing Kabeisatzes:
Required material
1x switch SEAT Original fir Start / Stop 630.905.218.A ATT
1x plug housing SEAT Original 8K0,973.754
4x Lettung 0,50 about 40cm long
4x Plug Gen (2.8 ACV Part No. 311173-x)
2x pieces - = fF3en- (z.8 ACV code 341173> x)
- Modification of the wiring harness
1. Poke out the wires pin 6 (grin / black) and pin 14 (blue) from the
Plug housing A off.
2. Make the additional line
3. Connect the additional cable and the cable set
(i) Line from pin of the line - connect to pin 14 of the connector housing A.
(ii) Lead from pin 2 of the cable - pin in pin 2 of the plug housing A
(iii) Wire from pin 3 of the wire - pin in pin 4 of the plug casing A
{iv) Connect wire from pin 4 of wire ~ to pin 6 of plug housing A.
