In a Leon with LED headlights there is no roller switch as the headlights are meant to be self levelling, mine seem slightly too low.
Ah yes that's right, in my Cupra there was no switch either! Must have been thinking of the FR
Brainfart..
If it's a Leon with the LED lights then thisHi, I’ve seen somewhere how to do this but can’t find it. How do you adjust the LED headlight angle? Some kind of screw under the bonnet if I remember rightly? Thanks!
Credit to Dephead2004
Consensus is that its screw TWO that alters height... but mark where you start from, and itll be obvious once you start.
Just what I was looking for, thanks. Will have a go tonight.If it's a Leon with the LED lights then this
Treat my Cupra to some Detailing Products.
Meguiars Smooth Surface Clay Kit - Never tried to clay a car before but the Cupra deserves it.
AutoGlym Bumper and Trim Gel to bring all that exterior black trim back to its best.
AutoGlym Perfect Polish Applicator for the Bumper and Trim Gel.
Just need a good weather day off work and away we go.
Don't ruin the applicator on trim gel. Any cloth will be ok. You will need to apply polish and or wax after claying too.
Fitted the LED reverse bulb to my facelift Leon, now all my external lights are LED and I can actually see where I’m reversing! Such an easy mod too, open boot, slide off cover, twist bulb holder and replace.
Bulb is a W16W and I just got a cheapish pair from eBay for about £5. Couldn’t bring myself to spend £20 on a pair of Osrams but if mine fails I might. No errors on dash though.What LED bulb did you fit?
Did it have 60mph signs?Drove mine to the gym today, got over taken by a moped with L plates on a dual carriage way (60limit)
I used my obdeleven tonight. Added purple and lime to my ambient lighting, so now I’ve 10 colours. Setup lock with ignition on so I can leave it running in winter to defrost. One click mirror folding, refuel quantity in dashboard, fan level display when in auto and put a W16W led bulb in the reverse light. I polished and waxed the car yesterday and scotchguarded the mats/carpets.
It’s been a productive couple of days since I collected the car and my wife loves it as I’m never indoors at the minute!
Lock with ignition? Unless you've got keyless entry how do you get back in?
