Thanks. That explains it then.5Q0955547B is the replacement of 5Q0955547A. They are the same. View attachment 1192
Sent from my LG-H870DS using Tapatalk
If there are no sensors at all fixed to the windscreen (take it you don't have climate control then?) then yes you'll need some cabling.
Cabling between where and where I don't know as its not something I've looked into.
Either the information is already on the forum somewhere or hopefully someone who knows will be along soon
Thanks for the info.
How can i check if i have climate control ?
I have individual temperature control knobs for air con ect.
you should have climate control then
Will this be ok for the facelift model?
Sent from my SM-G930F using Tapatalk
U can use the 1 already installed. The only thing that works without coding is the rain sensor, rest will need codingThat appears to be a MK7 Golf switch so should work OK, but will have white back lighting rather than red.
On another note when replacing the Humidity sensor for the Rain/ Light sensor do you need to remove and replace the gel pad or can you just fit it to the existing pad?
Can I fit the new sensor and leave my eBay auto light switch installed and get wipers to work without coding?
This will be temporary until I can find the correctly coloured switch
To get seat spec auto lights you need to replace the switch and the sensor located inside the rear view mirror casing, no wiring required as long as you have climate control.Another thing if someone can answer.
The china light switch comes with a light sensor wire.
If i manage to get a genuine Seat light switch will i need a light sensor wire or should it already be in the car somewhere
and match up with the genuine Seat light switch ?
Sent from my Moto G (5) Plus using Tapatalk
5Q0955547A. ?
When I did mine I used a sensor the same number except it ended in a "B"
Cheers i have ordered a 5Q0955547A. from ebay.
Just a switch to find now.
