Rain/Light Sensor Coding Mk3 FR
jacko5
187
35
60
UK
I have a Seat Leon FR 2014 without rain sensor and auto light lights.
If i get these parts HEAD LIGHT SWITCH 5G0941431AF and RLHS Sensor: 5Q0955547A
I think the RLHS Sensor: 5Q0955547A will be ok.
But i am unsure if i need a light sensor wire to go with the HEAD LIGHT SWITCH 5G0941431AF
So do i need a light sensor wire AND auto light switch if i get genuine parts ?
jacko5
187
35
60
UK
Nothing i don't think .. compared to my last car ..Scirocco had auto lights and behind the mirror on the windscreen looks different ( plain looking, no sensor pads or anything).
rcopus
270
8
Midlands
If there are no sensors at all fixed to the windscreen (take it you don't have climate control then?) then yes you'll need some cabling.
Cabling between where and where I don't know as its not something I've looked into.
Either the information is already on the forum somewhere or hopefully someone who knows will be along soon :)
jacko5
187
35
60
UK
Thanks for the info.
How can i check if i have climate control ?
I have individual temperature control knobs for air con ect.
iby104
76
10
Will this be ok for the facelift model?
Sent from my SM-G930F using Tapatalk
Jim45
316
86
That appears to be a MK7 Golf switch so should work OK, but will have white back lighting rather than red.
On another note when replacing the Humidity sensor for the Rain/ Light sensor do you need to remove and replace the gel pad or can you just fit it to the existing pad?
Can I fit the new sensor and leave my eBay auto light switch installed and get wipers to work without coding?
This will be temporary until I can find the correctly coloured switch
iby104
76
10
U can use the 1 already installed. The only thing that works without coding is the rain sensor, rest will need coding
Jim45
316
86
Thanks, I’m only interested in wipers at the moment as I have the eBay Auto light switch/ sensor that works fine, but when I find the correct SEAT light switch I’ll swap it out and code up the new switch with OBD11
jacko5
187
35
60
UK
Another thing if someone can answer.
The china light switch comes with a light sensor wire.
If i manage to get a genuine Seat light switch will i need a light sensor wire or should it already be in the car somewhere
and match up with the genuine Seat light switch ?
Andy1977
92
18
To get seat spec auto lights you need to replace the switch and the sensor located inside the rear view mirror casing, no wiring required as long as you have climate control.
Sent from my Moto G (5) Plus using Tapatalk
Reactions: jacko5
jacko5
187
35
60
UK
5Q0955547A. ?
Andy1977
92
18
Can't remember my switch code (it's up in this thread somewhere along with my Obdeleven guide) but it lights up the right colour (not white like a golf one will) and it came out of a Polo GTi.
Cheers i have ordered a 5Q0955547A. from ebay.
Just a switch to find now.
