Nothing because I only purchased 1 fan style screen wash jet thinking it was a pair ...
Fitted the pair, much better
Looks good! Do you have a link to the ones you bought?
Time 5 mins install (1 hour photos)
Level: Easy
Fan Jet Part No 5MO 955 985 C 9B9 non heated about £10 (See here eBay item number:221246183308 for an example of heated fans) or eBay item number:321197661391 for the ones I bought. You can pay more for SEAT branded ones from the same dealer but as you won't see the logo only you will know
Pistol Spray No 5FO 955 986
Pic 1 Comparison of pistol and fan . The fan is slightly deeper than the pistol but this did not matter to the install or effectiveness
Pic 2 Fan from top
Pic 3 Underside of fan. All clips are identical. It is a direct replacement by pulling towards the engine from the screen side and then in a downward motion.
Pic 4 A 2mm Allen Key is used to adjust the position of the jets on the screen in a vertical direction only. There is no horizontal adjustment as that is determined by the spray slot.
Pic 5 Underside of the original. Note the 3 jets. Here the black clip which retains the washer fluid tube securely has been slid to the right. Do not attempt to remove it. The pipe then easily pulls off. Fitting is a reverse.
Pic 6 The results from various angles
Comparison of jet of fine droplets covering the screen so well they are almost invisible in this shot. The 3 jets are well defined
Jet seen bottom right
Spray from inside the car showing coverage
So there you all are. I'll report back after a weeks trial. First impressions are that less fluid is used but that it is better distributed and will reduce wiper/ screen wear.
Bought these, genuine ones
The listing is for 1 so make sure you add 2 to your basket
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/253162770752
I was wondering if that was an ANPR van so checked the examples here:The wife went out in London last night for a work thing... being a good husband I took her back to her work earlier to collect her car rather than letting her get the train.
Don’t trust dashcam gps speed stamps so I’ve probably got a speed awareness course and a £92 bill coming my way
All the stupid s#%t I’ve done in that car I’m going to get a done for 36/37mph ... the irony is killing me!
Submit away.I was wondering if that was an ANPR van so checked the examples here:
https://www.pocketgpsworld.com/modules.php?name=Cameras&op=SubmitCamera
However, looks ominous although I'm not 100%. Hope you don't mind if I submit the location.
Checked out etka will maybe order from Skoda,cause price is even lower then this,I have 5 £ shipping costsI believe they are exactly the same
They will fit but they aren't heatedMy car has the Winter Pack, which includes heated washer jets, does anyone know if these will these still fit mine? Thanks.
Legend. Many thanksThey will fit but they aren't heated
Heated ones are part number
5M0 955 986 C
Bit more expensive, Amazon has genuine heated fan style ones around £30
https://www.google.co.uk/url?sa=t&s...FjABegQIABAB&usg=AOvVaw2fjE1POqobcelSuWEGagNU
The estate is fugly too.Traded places a few times with a Golf R on the way home from work.
Not sure I like the look of the Golf R, exhausts not half as sexy as the Cupra twins, standard red colour not as nice as Seat Desire Red, Body shape not to my liking either...only thing that I liked was the way the indicators worked in the style of Kitt (Knight rider for anyone under 30 lol).
Give me a Cupra any day..![]()
