Looks great zeffania. What treatment did you use? - always looking for improvement to the top coat polish I have used.
You may
Ebay - followed a link from earlier in this log.
As I can't post links enter this number into the above site - 371582121588
Just to say I bought the 540nm stabilus ones which are direct fit for the st but must be the same as the standard ones and unfortunately didn't pop the boot open as expected. I don't think as yet anybody has. I'd love to be proved wrong. I'd imagine it is only a case of a slightly more powerful version than standard with the same length, etc. E.g. 560nm but it would be trial and error unless somebody works for somewhere that sells them???What MK3 have you got? SC, 5 door or ST?
Only I bought some of these for my ST and they are nowhere near long enough.
Sent from my SM-G955F using Tapatalk
Only going on the basis of what was available for the st. As mentioned these were the right length and are rated at 540nm but they didnt do anything so got only guessing would need something more powerful. Otherwise as others have said in the past the alternative is its just not possible. I think this is unlikely, in any case search for stabilus leon st on ebay and it will come up with these models - 630499. If you can find something better I'll be very happy.I bought some from the item number mentioned. Definitely enough shove in them but they’re too short.
Ah found the problem.
I’ve ended up with part no: 017468
Instead of 630499
Doh!
Today I updated the maps to 820 ...
It came like this.Havent coded anything for carbon background.I like that carbon look background. Did yours come like that or require coding?
Sent from my G8441 using Tapatalk
I used my OBD11 to code come stuff on car,but dont have in apps option to put carbon.Maybe there is other kind of coding to put different backgrounds.Thanks bud. Thought that was the case. Been trying to find the guide to open up the extra menu, but struggling to search with the correct question
In cupra models is carbon background stock, you can try coding in vcds or obdeleven
Link to a Youtube video taalking you through the VCDS process:
https://www.youtube.com/watch?v=pd5LT7S4Px4
Essentially here is the steps to take depending on which year of car you have:
- Carbon Navi screen (for cars up to MY2015) Leon 5F,
Information Electrics,
Coding 70
Byte 17
Bit 0 false
Bit 1 true
Reboot the Radio (hold on/off button for 10 seconds)
- For cars from MY2016 or Navi plus, Leon 5F:
Coding 07
Byte 17
Bit 0 true
Bit 1 true
Radio reboot (hold on/off button for 10 seconds)
Do you have the Nav High unit with SSD ? Have you done a previous update by purchasing SD card or just downloaded files from Navigation.com onto a blan SD card and slotted it in ? Reason I ask is I understood that need Mapcare to use these updates.
