Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
well my wallet is £569.14 lighter after having my cambelt done today, so that dreaded noise that you get when you have a cambelt changed has gone, now ive got to sort out :eek:il leaks from cam cover gasket, turbo oil return pipe and sump bung, get another upper timing belt cover as its broken, there is a slight coolant leak from the oil cooler pipes, engine oil breather hose has collapsed, then theres 2 faults 16622 and 16497 to sort.
Ouch!
Sent from my iPad using Tapatalk Pro
rogercupra
174
Stapleford Nottingham
the crank case had collapsed so had to replace it, the plastic one that connects to that broke up too, so I replaced it all, I'm thinking of getting a catch can at some point, I need to get another backbox as it has a vrs one on and I don't like the sound.
Snark
18
Hi All
Sorted the drivers door window regulator on my Mk1 Leon 20VT, not my favourite job ! There is a very useful step by step guide up on VW Vortex at http://forums.vwvortex.com/showthread.php?1015107
Sad empty door frame, but now very clean inside with wide open drain holes, and plenty duct tape keeping the window in place while I sort out the new regulator.
Offending bust piece of plastic that should be holding cables and the window clamp ...
Nasty snarl made of the winding bobin when it all cut lose ...
New regulator set installed and tested, butyle tape ready on the edge of the panel to get a good watertight seal.
All back together again now and the inner door trim installed, electric window running fine.
Cheers, Snark
rogercupra
174
regulators are not the best of jobs to do, I did mine a month ago, my drivers side keeps coming off its clips for some reason so will sort that out as and when as its only a 5 min job to take the door card off.
vwtrev
Flying Banana
Oct 29, 2015
256
65
Essex, united kingdom
Not today, but in the last few days, Oil change and brake bleed + fitted rear brace, then took to Snetterton for a very Wet evening track session. Showed up a few Renault Clio's :)
mty12345
4,002
619
bristol
Dash gauge was showing the car overheating, live data showed that wasn't the case. New temp sensor sorted the issue.
NathyPhillips
68
24
United Kingdom
After having a pisser with the curb a month ago i finally got the parts i needed and fitted.
2 Used Front Bottom Arms with Powerflex Bush Upgrade (I Cleaned them up and painted)
2 New Ball Joins
2 New Track Rod Ends
All New Coilovers
4 Hours Fitting Them & A Nasty Cut To The Hand
Total Price......
Shed Loads!
Haze
344
Bought a new 710P DV from TPS £40 in anticipation of stage 1 remap, took the old one out just to see that it was also 710P! Never mind, that DV must have done going on 50K miles so a new one can't all be bad.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Took my Cupra out for a weekend fishing, then cleaned it completely, lastly sold it to my step son for £100 as an early Christmas present. Had to sell it couldn't just give it away completely. Gutted and happy all in one. Been with me for nearly 9 years. Been through thick and thin together.
At least it's in the family and I get to see it too.
Now I can get on with finishing my LCR.
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
2017 audi a3 2.0 tfsi fastback in white just got a swift lesson from the ko3.
I even let him get the jump hahaha.
Much fun had but time for bed
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Sent using The Force
I read in parkers it's only 187bhp stock, so wasn't really fair but he had them new indicators and the fact I was doing a sensible 70mph and he came up my ass at speed and pulled out at the last few feet.
There road tax is dirt cheap too!
Half what we pay
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Half what we pay
Would have thought it was more!
Surprising
BadBoy03
A Mk1 Is For Life, Not Just For Fun
Sep 6, 2016
714
495
Somerset
Glad to hear he can taxi you in style! Grats on passing test too. I had a D (dangerous) in first 5 mins on my test.. thought fk it, turned up stereo, put my arm on his head rest for reverse, did a wheelspin start. Had a very colourful report afterwards! ;)
Pleased your Cupra is staying with you :D
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Buddy this bloody tappy tipsy tappa talk rubbish. It's driving me mad.
I sent you a private message to explain. Before I posted the above.
Wanted to let you know and not be an ars about it as you clearly were very interested.
Clearly it didn't send it through.
Sorry buddy. He surprised me when he said he wanted it tbh as it's costing him a kings random. But a 1.3 fiesta was only about 600 less to insure.
Otherwise it was all yours.
Sorry once again bud.
Ps. Nice work in your test. Like your style.
BadBoy03
Sep 6, 2016
714
495
Somerset
No worries mate. Sorry I didn't get your pm. My mob does funny things, so could be my end. I'm really pleased your boy can fledge his wings looking cool. I had a metro, & I'm not talking MG! :blink:
