Fitted my tx intercooler![]()
Sent from my SM-G930F using Tapatalk
Thanks I bought the pipework seperate to cooler instead of buying tx kit. Worked out £150 cheaper, and was easy to keep fogsVery nice. Like the pipe work.
Was a stupid mistake by myself. Connection was tight on the nut but as I found out today wasn't tight on the battery so I pulled it off, cleaned it put it back on and connection is nice and tight. Starting first time now. Tbh I'm no sure if it has fixed the issue completely or not so I'll carry some tools just incasewhat was the zero power issue Andrew?
Just done the resistor mod for the fans and all is well now no stop start on the high speed![]()
There is a common problem with the cooling fans. There is slow speed and high speed. The problem is that the slow speed resistors burn out which means there is only high speed left. I noticed when I turned my aircon on the high speed would click on for about 30 seconds then click off then back on etc, when aircon is on the fans should be on slow speed and on constant, also slow speed should kick in when temps at about 90, high speed is to catch any possible overheating. So there's two options buy new fans at aboutExcuse my ignorance but what does your mod do exactly?
£400 or do this mod for £25
Will defo do that if the fans play up again3RD option £80 for both fans of the bay and 3 year warranty![]()
