Hi guys,
After a few months of getting some cash together, i ordered a new set of ebc discs and pads all round as mine were getting knackered.
Had the front set fitted along with the g201 abs pressure sensor jobbie done on my car.
Couldn't fit the rears yet as the rear calipers are well and truly..... shot (getting them fitted this week.) Back to the g201- it has finally cleared the annoying fault where my tire pressure monitor light was constantly on and the non existent abs & esp.
Problem is, along with what i think is a VERY newly slipping clutch (started today) is that the ESP(TCS) still doesn't turn on or off (pretty sure its permanently off).
No traction control light on the dash, no flashing light on dash or any assistance when the tyres spin up(unless what i believe to be the clutch slipping is actually the ESP trying to help) No error codes via Vag Com or anything that helps me in any way.
The light behind the ESP button to turn it on/off doesn't even illuminate in red when the lights are on, like all the other switches and dials etc. It's asif the switch or button is dead.
It has never illuminated since i got the car over a year ago (Yes, the problem has been there that long) but i just chalked that down to the g201 fault, so i didn't think anything of it.
Still bedding the brakes so i'm not able to stomp on them or really push the car to test that the abs is actually working yet, but i'm hoping that will be fine as the fault is cleared and the tire pressure monitor is working again
Any ideas on where to start?
Could is possibly be as simple as a replacement switch? Maybe there's a fuse that has been pulled/blown that could just need changing, possibly hiding the light on the dash?
After all of this, i'm left with 0 cash, an m.o.t next month which needs a cv boot and track rod end, potentially a nice big upcoming bill for the clutch and as I'm currently not able to conduct any real tests, Its leaving me in panic mode. (more so about the clutch)
HELP?
HELP?
