Has anybody had a letter from the royal mail asking for details about their obd11 purchase ? Bought mine October last year, just had a letter but I'm not sure what they are trying to establish
What does the letter say?
I agree. The sender will most likely be flagged due to the volume of mail coming into the country.That does seem very strange. Unless they're seeing a lot of packages from its country of origin and are wondering what they are?
I haven't heard anything from them.
Sent from my SM-T520 using Tapatalk
Wondering if anyone might be able to help....
I've noticed a couple of issues since I've made changes.
The first one is when you put the ignition on for the first time, if the climate control is set to any kind of on setting it doesn't actually work unless I press one of the heating controls?
The second is that my coming home/leaving lights do not seem to be working at all now? I've checked settings on the car as well as in OBDeleven and everything I can see says on?
Any help would be appreciated. Thanks in advance.
Hi, how did you do it? Can you share the coding?
This is the problem with some of these tools unfortunately. All to easy to get carried away with a load of changes and then find that something else has got screwed up in the process and you have no idea which of the changes you made caused the problem or how to set everything back to the stock factory settings again.
I'm not sure if the "apps" record their changed in the "History" section but have a look in there. You might have to revert all the changes you made (i.e. back to a stock setup) to see if your climate controls and CH/LH lights start working again. Then apply your changes one at a time to again see which one "breaks" those other things.
I'm sure this does it as standard. My FR did it and my Cupra definitely does it without making any mods;
Press hard and find out
