That does seem very strange. Unless they're seeing a lot of packages from its country of origin and are wondering what they are?
I haven't heard anything from them.
Sent from my SM-T520 using Tapatalk
I agree. The sender will most likely be flagged due to the volume of mail coming into the country.
I'm wondering if they are sending them as domestic mail/gifts to avoid fees?
Sent from my SM-G955F using Tapatalk
If they are coming from outside the EU then the buyer may be liable for import/VAT fees, so I would recommend not responding to the RM letter.
finally get this wipers bits done :)
Wondering if anyone might be able to help....
I've noticed a couple of issues since I've made changes.
The first one is when you put the ignition on for the first time, if the climate control is set to any kind of on setting it doesn't actually work unless I press one of the heating controls?
The second is that my coming home/leaving lights do not seem to be working at all now? I've checked settings on the car as well as in OBDeleven and everything I can see says on?
Any help would be appreciated. Thanks in advance.
This is the problem with some of these tools unfortunately. All to easy to get carried away with a load of changes and then find that something else has got screwed up in the process and you have no idea which of the changes you made caused the problem or how to set everything back to the stock factory settings again.
I'm not sure if the "apps" record their changed in the "History" section but have a look in there. You might have to revert all the changes you made (i.e. back to a stock setup) to see if your climate controls and CH/LH lights start working again. Then apply your changes one at a time to again see which one "breaks" those other things.
Hi, how did you do it? Can you share the coding?
First of all do this modification in module 09
1 - Electronic control module 09-. Code (31347)
2 - Adaptation
3 - wiper
4 - Menuesteuerung konfortwischen HW
5 - Change value to On
Then you need to activate setting in 5F unit otherwise you can control it and wiper going to run all the time on AUTO
1 - Electronic control module 5F-.
2 - Adaptation
This two menu need to bit of adjustment :)
First modify section Function list BAP
After that go to other menu Vehicle menu operation
Red marked need to be change
After you have finished with this mod need to reboot unit hold down power button until you hear crack in speakers
And that's it ;)
Thought this might be the case. I think I've figured out my lights issue, but still stuck with the climate control. Might have to go stock then! Cheers bud.
Evening all,
Pick up my new Leon St Fr tomorrow and wondering if anybody near Dundee would be willing to swap some OBDeleven coding to be done on my car for some beer or beer tokens? Happy to come to you or meet somewhere neutral.
this isn't value this is long code for 5F unit. Dont know what value are looking for? This code is for whole unit
I have an error code I think because I've made this change:
Long coding
Control unit: 5F Information Control Unit
Old value:
04730001D70A000011111101008808002F0201C60120010046
New value:
04730001D70A000011111101008808002F0301C60120010046
And I want to change the old value back, but I don't remember how to do it.
Trouble codes:
B126CF2 - Navigation system Navigation database not enabled
Intermittent
Malfunction frequency counter: 63
Dynamic environmental data: 02867C
Date: 2017-04-07 21:41:50
Mileage: 6984 km
Unlearning counter: 11
Priority: 6
sebastian: go to long code mode and then byte 17 clear tick on byte 0. anyway your error code is probably because you tried on your unit different map card?
Does anyone know how to turn on hazards under heavy braking, I've seen it in the apps part but wondering if someone knows how to do it without buying/using credits
I'm sure this does it as standard. My FR did it and my Cupra definitely does it without making any mods;
Press hard and find out :D
Ive just got a standard 1.6tdi Tech pack Leon :p
have slammed the brakes hard before nothing happened so was wanting it turned on as its a good feature to have
