If values in mvb 031 match each other at high rpm under full throttle through 3rd/4th gear it's not fuel filter.
My advice, smoke test inlet for PCV and vac pipe leaks.
If no joy check evap valve isn't letting unmetered air through.
Smoke test exhaust for leaks before the first oxygen sensor too.
