hello,
i have a 2000 Seat Leon 1.9TDI. i had my car battery changed and since then have had a fault with my central locking, electric windows and wing mirror control. it started immediately after the battery was changed. Everything else inside, including the interior lights, works as normal. i'll try and include as much info as possible.
-when i press the key fob it only locks and unlocks the boot, none of the doors respond. i have tried pressing it two times in succession, however still only the boot works. when pressing the lock button it also sets the alarm as normal.
-when i unlock the doors manually with the key it only opens the drivers door, and the button on the inside of the car to unlock the doors only works on the drivers door.
-the controls for the electric windows and wing mirrors don't work. however if i put the key in the door from the outside and hold it in the unlock position it will make the window go down, if i hold it in the lock position the window will go back up, as it should do.
- the battery drains when the car is turned off, which again is a new problem which started at the same time as everything else. The only way for it not to drain is if i disconnect the negative when its not being driven.
i have checked and changed the fuses that control the central locking, however no luck. i have also tried lots of the re-programming tricks for the key fob which have been posted on other threads.
i know it cant be a fuse problem as the interior lights still work which are connected to the same fuse as the central locking. i doubt it is a CCM or central locking pump problem as the boot still works and it isn't something that suddenly started, it happened when the battery was changed. also the same mechanic connected to his computer and got a diagnosis for there being no power going to the CCM, so we changed it with a new one and it still didn't work.
i have read somewhere about people having similar issues and it being a security issue recorded , which stops power going to the central locking and windows, stopping from working. They reset the unit and it went but there was no information on how or what they did.
if anyone has experienced a similar problem or has any ideas what the issue might be, please let me know. any help would be appreciated.
