Installed such, but I have problem on the right side. On highest position possible most of the stream hits the arm of the wiper. Is it possible I have wrong variant?
The other issue is that water returns back to the container and doesn't stay in the pipes, so it takes very long before it starts spraying after I pull the switch. Sometimes wipers start even before they start spraying. Anyone solve that problem?
They're adjusted to highest possible position.As for the aim of yours, not tried adjusting them? They fit several cars.
Fully clipped. I adjusted them. And cannot adjust higher.I'd check that they were clipped in fully.
If not remove and look whilst you adjust.
No movement? Return to sender!
I'm going to return them, as they're crappy. Need to find other set.
Not sure, how to recognize? These doesn't have allen screw, but the one for flat screw.Genuine ones?
I have these ones also... I found that the original pistol spray jets squirmed at the wiper arm. It's just how they're situated under the bonnet and the position of the arm. I never found it an issue as when the wiper arm moves it then hits the screen.Not sure, how to recognize? These doesn't have allen screw, but the one for flat screw.
Good luck with your ownership and enjoy the clear screen
