ordered my obdeleven pro yesterday, looking forward to giving it a go
A slightly sideways question, but is there anything against leaving the gizmo permanently in its slot under the steering wheel, or should you (as I have done until now) only slot it in when you need it?
Has anyone tried doing any of these? I seen a youtube vid of a cupra with hazard lights on and the rear lights were blinking with indicator lights looked quite good. Still waiting on mine arriving to try out and not sure which 1 it will be either.
Flashing LED DRL dissipated
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select - Leuchte2SL VLB10
4 - Sub - Lichtfunktion CD 2
5 - Change value Blinken links aktiv (Beide phasen)
6 - Select - Leuchte2SL VLB10
7 - Sub - Dimmwert GH 2
8 - Change value to 36
9 - Select Leuchte2SL VLB10
10 - Sub - Dimming direction GH 2
11 - Change value to Minimize
12 - Select - Leuchte3SL VRB21
13 - Sub - Lichtfunktion G 3
14 - Change value Blinken links aktiv (Beide phasen)
15 - Select - Leuchte3SL VRB21
16 - Sub - Dimmwert GH 3
17 - Change value to 36
18 - Select - Leuchte3SL VRB21
19 - Sub - Dimming direction GH 3
20 - Change value to Minimize
Flashing DRL Simultaneous with bi-xenon headlights Basic
2 - Adaptation
3 - Select - Leuchte4TFL LB4
4 - Sub - Lichtfunktion C4
5 - Change value to Not active
6 - Select - Lichtfunktion C 5
7 - Change value to Not active
Flashing lights DRL with LED simultaneous
2 - Adaptation
4 - Sub - Lichtfunktion G 2
5 - Change value Blinken links Dunkphase
8 - Change to the desired value
9 - Select - Leuchte2SL VLB10
14 - Change value Blinken links Dunkphase
17 - Change the desired value
Like a Christmas tree but Christmas are closeif see this on the road i would think that there si something wrong with the wires
Sent from my Nexus 6P using Tapatalk
Is is possible, please, to disable the yellow light which comes on when not in Normal mode? Like many people, I usually drive in Sport and would prefer not seeing this particularly "warning".
It took a while for mine to arrive, I think 10 working days is probably a good estimate but it was a lot longer than your average amazon purchase would take.Ordered one of these on the 3rd November. Still not received it yet! How long has everyone waited for it to be delivered?
A week or a bit longer for mine as well.It took a while for mine to arrive, I think 10 working days is probably a good estimate but it was a lot longer than your average amazon purchase would take.
Sent from my XT1572 using Tapatalk
