OBDeleven modifications
p.eco
227
17
Ireland
You don't actually have to pay for apps. Every day you can get few credits, but if you change date forward on your phone, open app it will add credits. You can do this over and over, depends how many credits you need.
Sent from my Nexus 6P using Tapatalk
Reactions: Sham and Woody_72
dsr
111
11
Norwich
How sneaky can you get! Like it.
Reactions: Sham
Havsgaard
186
Denmark
Drive Profile on ODB
Select Control unit 19
Control unit long coding
Byte 08
Bit 4 Activate
ESP on Car Menu
Select Control unit 03
Byte 29
New Value 09
Oil Temprature on ODB
Select Control unit 17
Byte 10
Bit 01 Activate
Fog Lights With Blinker
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
(2)-Static AFS Light Vorschrift
Value=FMVSS 517 108
Increase Intensity of Rear Lights
Security access
Access Code 31347
Adaptation
(6)-Leuchte28RFL LC11-dimmwert AB28
Value=100
(6)-Leuchte29RFL RA64-dimmwert AB29
Value=100
Disable Start/Stop
Adaptation
Start Stop Limit voltage
Value=12
LED Fog Light Warning Delete
Security access
Access code 31347
Adaptation
(1)LB45-Leuchte12NL Lasttyp-12
Value= 6-LED Lichtmodule
(6)Leuchte12NL LB45-Dimmwert AB 12
Value=127
XDS Adjustment
Select Control unit 03 (ABS)
Adaptation
Select: Expanded Electronic Differential Lock
Options: Weak-Normal-Hard
Dynamic Breaks
Select Control unit 03 (Brakes)
Adaptation
Channel 09
Value 2
Break Drying System
Adaptation
Select: Disc Drying
Rain Closing
Security access
Access code 31347
Adaptation
(15) Access Control 2-Regenschliessen_ein_aus
Value: Permanent
(16) Access Control 2-Regenschliessen_art
Value: Permanent
(28) Zugriffskontrolle 2-Menuesteuerung Regenschliessen
Value:Aktif
Control unit Long Coding
Subsystem: Rain / Light Sensor (RLS)
Byte 0
Bit 1-Bit 2 DeActivate
Activation of OPS
Select Control unit 10 (Assistance Situation)
Security access
Access Code 71679
Byte 2
Bit 0 Activate
Led and Blinker Lights in Same Phase
Security access
Access Code 31347
Adaptation
(16)-Leuchte2SL VLB10-Lichtfunktion G 2
Select: Blinken Links Dunkelphase
(18)-Leuchte2SL VLB10-Dimmwert GH 2
Select: yeni deger 0
(19)-Leuchte2SL VLB10-Dimming Direction GH 2
Select: yeni deger minimize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3
(18)-Leuchte3SL VRB21-Dimmwert GH 3
(19)-Leuchte3SL VRB21-Dimming Direction GH 3
Fan Speed on Auto Mod
Select Control unit 08 (Air condition A/C)
Byte 11
Bit 6 Activate
Adjustment Door Led Light Intensity
Security access
Access Code 31347
Adaptation
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
Select: max 127
(6)-Leuchte17TFLR SRB3TFL R SR KC3-Dimmwert AB 17
Select: max 127
Avoid Dimming LED Lights when Blinking
Security access
Access Code 31347
Adaptation
(12)-Leuchte2SL VLB10-Lichtfunction E2
Select: not active
(12)-Leuchte3SL VRB21-Lichtfunction E3
Select: not active
Cornering Fog Light Activation
Security access
Access Code 31347
Adaptation
(5) Leuchte12NL LB45-Lichtfunktion B12 auswählen
Select:Abbiegelicht links
(5) Leuchte13NL RB5-Lichtfunktion B13 auswählen
Select:Abbiegelicht rechts
Adjusting Cornering Fog Light Sensitivity
Security access
Security Code 31347
Adaptation
(3) Static cornering light lower speed threshold
New Value=0
(4) Static cornering light upper speed threshold
New Value=50
CD Eject Button Activation
Select Control unit 5F (Informationselektronik)
Adaptation
Button for CD eject status
Value=Blocked
Folding Right Mirror in Rear
Select Control unit 52 (Türelektr. Beifahr.)
Byte 04
Bit 2-Activate
Bit 3-Activate
Access Code 31347
Adaptation
(15) Access Control 2-Spiegelabsenkung bei Rueckwaertsfahrt
Value=Active
(20) Access Control 2-Menuesteuerung Spiegelabsenkung
Value=Active
Hill Hold Assist Duration
Adaptation
Select Berganfahrassistent
Adjust as you wish. (default: Normal)
US Parking Lights
Security access
Access Code 31347
Adaptation
(9) 0 BLK light fitting VL B36-light function D 0 Select (turn signal front left)
Select Standlicht allgemein
(10) 0 BLK light fitting VL B36-dimming select CD 0
Value:30
(9) -Leuchte1BLK VRB20 light function D 1 Select (Indicator front right)
(10) -Leuchte1BLK VRB20-dimming CD 1
Value:30
(12) -Leuchte0BLK VL-B36 Lichfunktion E Select 0
Select Blinken links Dunkelphase
(15) -Leuchte0BLK VL B36 dimming Direction EF
Select Minimize
(12) -Leuchte1BLK VRB20 Light Function E 1
Select Blinken rechts Dunkelphase
(15) -Leuchte1BLK VRB20 dimming Direction EF
Select Minimize
Refueling Gasoline Amount
Select Control unit 17 (Dashboard)
Byte 10
Bit 4 Activate
Comin Home Lighting Duration
Security access
Access Code 31347
Adaptation
(3) Comfort illumination-Menueeinstellung Cominghome
Value (Default: 15 seconds - maximum: 60 seconds)
Comin Home/Leaving Home with Fog and LED
Security access
Access Code 31347
Adaptation
(4) Comfort lighting Coming Home Lights
Value :Nebellicht(Low Beam)
Lock Acknowlegde with Horn
Security access
Access code 31347
Adaptation
(1)feedback signals-Acoustic feedback
Value=Yes
(2)Lock feedback signals-Acoustic feedback
Value=Yes
(8)feedback signals-Acoustic feedback global
Value=Aktive
(7)feedback signals-Acoustic feedback
Value=Active
(8)feedback signals-Acoustic feedback duration
Value=Short(kurz)
Shot Down Warning Tone for Parking System
Adaptation
Park Assist Activation Tone
Value=OFF
Parking Varning Distance Change
Adaptation
Shutdown parking aid
Value=20km/h
OPS Warning Line Closing
Security access
Access code:71679
Control unit Coding
Byte 1
Bit 5 DeActivate
Closing Windows When Iglite Off
Security access
Access Code 31347
Adaptation
(13) -Zugangskontrolle 2 released trailing FH cancel at Tueroeffnen
Value=Aktif
FIS Carbon
Adaptation
Screen view
Value=Option 2
Seat Belt Warning Deactivation
Adaptation
Select:Disable channel belt warning
Value:Yes
Byte 0
Bit 2-4 DeActivate
De-Fogger Timer
Security access
Access Code 31347
Adaptation
(3) Window Air condition A/C condition A/C rear window heating value
Type Duration how long you want to.
Rear Wiper Adjustment on Car Menu
Security access
Access code 31347
Adaptation
(2) Select Rear wiper-menu control Comfort Wipe HW
Value=Not Active
Comfort Blink Cycle
Security access
Access Code 31347
Adaptation
Comfort Sinyal Sayisi (Cycles)
Value: 1-5 Value 3 (standard - 3x blinking)
Traffic Sign Assist Activation
Select Control unit 5F (Information Electrical)
Adaptation
Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21
Deger=Active
Select channel (151) vehicle menu operation-menu_display_road_sign_identification
Deger=Active
Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_threshold_high
Deger=Active
Control unit A5 (front / advance camera)
Security access
Access Code 20103
Byte 1
Bit 0 Activate - "01 Traffic Sign Recognition (FTE) active"
Byte 5
Bit 2 Aktivate
Adaptation
Select : channel numbers indicate end of speed limit
Importance to actively invest Show Valid suffix
View Channel Valid suffix
Corresponding value adjust default: 00100111
Line Assist Activation
Bye 4
Bit 6 Activate
Bye 11
Bit 1 Activate
Select Control unit A5 (front / advance camera)
Bye 0
Bit 0 Activate
Security access
Access Code 20103
Adaptation
Channel - Seçim HCA_On_State
Put emphasis on menu
Channel - Seçim HCA_Warning_intensity
Channel - Seçim BAP_Personalisierung
Put emphasis on not activated
Select the time of engagement
Set adjustment via menu - emphasis on late
Select Personalization spurt holding an assistant to a terminal 15 - channel
Set value to last setting
Select Control unit 44 (power steering)
Bye 0
Bit 0 Aktif
Adaptation
(49) function -Vehicle list BAP LDW_HCA_0x19
Activate
(21) vehicle menu operation-menu_display_Lane_Departure_Warning
Activate
(23) vehicle menu Bedienung_menu_display_Lane_Departure_Warning_over_threshold_high – channel
Activate
Lap Timer Aktivation
Byte 1
Bit 3 Activate
Pointer Test
Byte 1
Bit 0 Activate
Adjusting Microphone Sensitivity
Select Control unit 5F (infotainment)
Adaptation
Select Mikrofonempfindlichtkeit (Microphone Sensitivity)
Adjust value as you wish.
Sunroof Opening With Remote Control
Security access
Access Code 31347
Adaptation
(9) - Zugangskontrolle 2 - SAD Richtung Komfortöffnen auswählen
Value=Tilting
Presentation Mode
Select Control unit 55
Security access
Access Code 20103
Adaptation
Presentation Mode
Value=Active
Line Assist Adjustments
Steering Wheel Vibration
Select Control unit A5 (camera)
Security access
Enter unlock code 20103
Adaptation
Select channel intensity steering wheel vibration
Value adjust accordingly Default: medium options: early, middle, late
Blocking of Drivers Reaction
Security access
Adaptation
Select channel deactivation threshold driver activity
Steering Wheel Support
Security access
Adaptation
Select channel intensity wheel support
DLR Only in Auto Mode
Security access
Access Code 31347
Adaptation
(9) - Select daytime running lights only in switch position auto
Value=Aktif
DLR Control on Car Menu
Security access
Access Code 31347
Adaptation
(2) Daytime running light activation by BAP or Operating sequence possible
Value=Aktif
Adjust Consumption Indicator
Adaptation
Customize consumption indicator
Basic Degeri 100
Value change 85 (%) and 115 (%) .
Andy90
210
it doesn't. it did with the beta version but not the final.
Send them an email and they'll send you the link to download the beta again. I've currently got it and works on mk3
Sent from my SM-G925F using Tapatalk
Andy90
210
How much is the device/pro package please anyone?
dw911
1,036
7
Hi any chance you could post the link please?
When I enquired and suggested is it not possible to just installed the earlier software on the cable so at least I can use it on the Mk3 , they were helpful, but just said it's not possible once 16.8 is installed on the cable :confused:
Andy90
210
Email [email protected] with the email you use for your Android/ios account asking for the beta version and they'll get back to you.
dw911
1,036
7
Thanks for the reply, my mistake though, though you were talking about a beta fix for the vcds cable
Thanks anyway :)
dsr
111
11
Norwich
Simply to say I now have my "PRO" version.
Set up and first software change (the sound actuator volume) made. Looking forward to playing some more.
An awesome piece of kit at a very realistic price.
AndrewJB
Aug 16, 2007
11,175
485
Maranello
can anybody post a screen shot of the options it provides for Leon, Need to decide if its worth getting as I already have most of the stuff turned on when I had a dodgy copy of VCDS, I also have Carista.
bretth1974
561
It's quite difficult to do as there are a lot of sub menus. The options are pretty much the same for Leon, golf, A3 so do a google search and there are several reviews. Also someone posted a list of the adaptations on here earlier which gives you a run down of what it can do.
Sent from my SM-G900F using Tapatalk
