Firstly...Manual does not say any words
how to change bulb of indicator (outer light) in ST, just regular Leon.
Secondly..Picture which describes
how to remove outer light to change indicator bulb is useless. It shows only light with some crazy arrows.
I understood that I have to unscrew fixing screw, ok, and then to do a bit rotating movement outwards from the boot.
It is impossible to move light directly out, you have to rotate it a bit.
And these fixing points cracks easily. As you see, both fixing points stays in a place, fixing points at light cracks..
I have a feeling somebody screwed fixing points into light too heavily and they both cracked with first try to put light out. Second light I was able to do it without any cracks and everything is ok.
