Rain/Light Sensor Coding Mk3 FR
FRvirgin
28
11
S Yorks
Fitted my sensor, 5 min job, and auto wipers working just fine. Not sure if I'm going to splash out on the auto light switch as I do not have VCDS and you can leave the switch on dipped beam and they go off with ignition so this time if year not much call for full auto.
Has anyone managed to source a genuine Seat auto light switch off ebay with the red back lighting or are they all VW units?
stu_m
629
52
Hull
www.themotorbikeforum.co.uk
if you fill out your location some may be able to help if they are nearby
if you want it on of course :)
Max M4X WW
50
Nr. Guildford
Hi all,
My sensor arrived from Spanish ebay today so I'm going to attempt to fit it. Does anyone know the cheapest place to get a switch? The Leon ones seem hard to come by.
Then I will need to track someone down in the Hampshire area to do the coding :D
bobajob69
24
Southampton, UK
^^This^^
Me Too! mine also should have arrived from spanish ebay today and i'm also after a light switch. Seat quoted £160 for the switch (they wanted £140 for the sensor).
Also after someone with a vcds and some magic in southampton but willing to travel....
FRvirgin
28
11
S Yorks
If anyone does get the proper switch with red illumination, I'd be grateful if the part no could be posted up so if any do come up on ebay we can at least buy with confidence that we've got the right part.
Max M4X WW
50
Nr. Guildford
My switch has arrived but I'm not sure if I should test the lighting colour without having the switch coded as I don't want to cause any lighting errors!
Now I need to find someone to code it :)
Chrismalkinuk
102
Stoke on Trent
anyone know what the following errors are on VCDS? After getting the rain/light sensor to work, i clicked the wrong box and now have an error on the car of Headlights...
Tuesday,09,February,2016,15:51:52:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: VSSZZZ5FZFR107986 License Plate: DF65VDP
Mileage: 1988 Repair Order:
Address 55: Headlight Range Labels: 5Q0-907-357.clb
Control Module Part Number: 5Q0 907 357 HW: 6R0 907 357 A
Component and/or Version: LWR-ECU 005 0080
Software Coding: 049C000009000000
Work Shop Code: WSC 39343 001 104857
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110 (SE37)
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75F82ECB85C1CF2A3CF6DF9-8020
Fault Codes have been Erased
1 Fault Found:
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 137
Mileage: 3200 km
Date: 2016.02.09
Time: 15:51:21
n4src
Hi all just did it!! Wipers work automatically but not exist as an option on car settings to enable or disable them i did all the steps mentioned. Maybe i need to do a reset on the infotainment system??
Ben.
23
South Ayrshire
I've found a lot of rain sensors for a VW Golf 7 but with a different part number 8U0 955 559 B & another with 5O0 955 559, has anyone used either of those part numbers? Both say they are Rain, light and humidity sensors.
n4src
Also today i got my lights switch. I can confirm all is working !!!
The wipers do work automaticaly as soon as you start to drive so no problem.
