Yeah, but not in that sexy wayunless you have them in stockings and suspenders
I wait till shearing time, I like mine naked......
Tried for the second day running to fit the Lockwood stainless steel sill protectors. It was dry on both days 'till I went out to do the fitting!
I do like the look of that splittersets of the front nicely. If I wasn't in a leased cupra I would have fitted one.
Finally got around to fitting my triple r front splitter that's been sat in the garage for over a month..
Wasn't too bad to fit. U have to remove both bottom engine covers for access inside the bottom of the bumper. line it up and made sure you're happy with the position. Clamp it in place or get a couple of people to hold it up. Then drill and bolt it up with the nuts and bolts supplied with it. Definitely made it easier being able to do it up on a workshop ramp. Could see it being tricky doing it jacked up lay on your back! There's a fitting guide on the website. You would have to contact them regarding postage.How difficult is it to fit? How is it mounted?
Do they send it to the old Europe as well?
