Did you actually dry out the footwells after doing the door liner and pollen filter? It holds a surprising amount under the carpet.
Did you use sealant when putting the pollen filter housing back in place and make sure the cover and its skirts were positioned correctly (old ones can be a bit misshapen over the years).
Did you clear out the drain hole to the side of it?
Did you also check the drain holes in the door were clear?
To test, secure a strip of paper along the door just under the inner panel then run plenty of water down the outside window. See if the paper stays dry. I would expect the lower rubber to be wet in normal use anyway.
Hi thanks for the detailed reply . I have sorted out the pollen fillter cover as it was not fitted correctly and the drain hole for it is clear this seems to have fixed the passanger side front water problem out . The rear is still leaking had the door card off again to check for leaks around the the metal door panel and have stripped all of the plastics from inside so I could see what is going on but I can't see a drop coming if after putting about 50 L of water on Window seals and all round the door and the pollen fillter and I still can see any droplets of water any where but the is still water getting into the passanger side rear footwell some how . So today I have cut some holes in the rubber covering the drain holes in the door and also noticed that the rubber what has the cables running in it for the door where it goes into the chassis /body of the car and the door there was a few droplets of water dripping down the edge of the door where hinges are feom that rubber so have sealed both sides up as I thought it may be leaking in there and running down behind where the passanger seat belt is causing the rear footwell to be wet has any one herd of this before ? .
Many thanks
