They look good. So they have the transponder in the key and they just need to be programmed into the car? Can you do that yourself?
Yep, they come as a complete key, I just need to get skc from the ecu or cluster and I'll be able to program them in, iv a few different cables for when I had my b5.5 Passat and I took the skc from that so all should be good, I'll get the blades cut and then hopefully have them programmed in later :)
Clutch will also be done today, so it'll be an adventurous weekend.
[/IMG]
I just made and fitted this! But will probably be a track toy only :-( but dpes spund ok!
Sent from my SM-A500FU using Tapatalk
Christ! Busy this weekend then?? LoL
I recently had my gearbox and clutch replaced! Bloody selector pin failed :-(
I hope my selector pin don't fail as I'll be buggered if I'm getting the box out in a hurry, a real tight squeeze with the subframe still in, and you need to contort the engine and box and swivel the diff round the subframe so the box will clear the dmf, as usual it just popped straight back on, I nearly gave up if I'm honest as doing it on my back outside was a ball ache as usual.
Still it was easier than the Passat box, and my pedal is so much lighter now with a new slave cylinder, the old clutch has a chance of being the original, it's was breaking down and nearly ready to pop, I was on borrowed time before it poo'd itself and disintegrated in the box.
Oh and to top it off this morning I popped into the local key cutting place and they moaned that the Internet keys damage there blades and I have to go somewhere that charges £60 a blade to have them cut, I think I'll go down to the spotty teenagers at Tompsons and get them to do it.
Knackered clutch
Box back in and just getting things done up :)
Knackered clutch
Shiiiiiiite! Yeah, all i did was stop to let a woman through, went to select 1st and..........damn! But i was gonna do it myself, but would have lost me rag, so paid 160 for someone to fit :) happy days and my pedal! God aint they light :)
Just replaced my N75 valve and the large majority of the original vacuum tubing to silicone, only pipes not changed so far are the ASV and the turbo actuator (turbo actuator would have been done if I could have got my arm down the engine!) :D
Took me a lot longer to do than I anticipated too, though at least no breaks happened! :)
--Lee
Today I managed to get one of the keys cut and also coded to the car after faffing trying to remember how to pull the skc from the cars ecu, fitted a stereo as I need hands free and after the clutch change and disconnecting the battery the original unit needed the code which I obviously didn't have, then washed mine and the misses car as mine was disgusting.
Pocked the micro switch on my bonnet catch to reset my oil light.
This forum is great! Don't know how long it would have taken me to find that fix!!
Kind regards,
W
Done this to mine a while back (just for the sake of it really) and only had the pipe pop off once, but it does sound a wee bit better - not convinced there is a power gain of any sort ;)
Yeah...it seems to have a bit more lag on pick up but then goes like a stink from there :)
Sent from my LG-D802 using Tapatalk
Need some uprated parts but not sure what to get
Hi I'm in need of some uprated parts for my Leon Cupra mk1 I'm after a nice induction kit exhaust and what the best dv I should get thanks
Stephen
Well I decided to go down and give my engine bay a little clean, and this was the outcome be four and after, I no what ur gonna say there's not much difference lol
B4
After
Also put my new wind deflectors on all four windows, just waiting on my rim protectors to arrive, they got lost in the post so there sending me another set out.
19 hrs of detailing, clay barred twice, full set of Lake Country pads, megs ultimate compound and 205, tons of dodo wax was then megs aqua wax.
Sent from my LG-D855 using Tapatalk
Yeah lol hopefully their **** should slide right off it , 5 applications of dodo wax and 3 of aqua wax God I even cut half my tree off so they don't sit above the motor and crap all over the place! So 20 hrs all together. Thanks mate for the comment, tis very shiny
