Aftermarket Brake Kits / Brembo Retrofit Cupra
Pestonio
21
Hi guys
I am hoping someone here can help; does anyone know the cost of getting the performance pack brake kit retrofitted on a Cupra 280? Or does anyone know of any aftermarket kits?
I looked around and couldn't really find anything for the newest models but want to upgrade. I had a big brake kit on my previous cars and kind of regret not getting the option this time, I have found the stock brakes to be a little 'soft' so would like something with a little more bite.
Similarly, the stock pads produce a ridiculous amount of dust so does anyone know of any decent replacements? No EBC RedStuff available yet apparently...
Many thanks
Pete
AndrewJB
Aug 16, 2007
11,175
485
Maranello
There is loads of options out there, any that fit the MK2 will fit the MK3.
Ive got Ferrari F40 calipers, 370mm 2 piece disks.
Pestonio
21
Thanks guys.
Good to know that Mk2 kits will fit the Mk3, they're pretty easy to find compared to Mk3 specific kits.
Anyone know how much Seat would charge for a Sub8 retrofit? I think it was about £3k as an option new so I doubt it'll be more affordable than an aftermarket equivalent. Might contact my local garage and enquire...
Fmxvxx
387
I doubt it will be viable cost wise to retro fit the cost saving are made because they dont have to fit the original parts having to buy it all and be left with the used parts of which the resale value will suck because nobody has a need for mk3 cupra stock brakes etc.
The Michelin cup sport 2 tyres with those brembo's though transform the car, so worth an enquiry.
chrisRibiza
1,194
51
Dave from SERE posted up the part numbers / prices for the 370mm brake upgrade - http://seatcupra.net/forums/showthread.php?t=421600
5F0 073 910 LH caliper red £387.65
5F0 073 910 A RH caliper red £387.65
5F0 073 910 B LH caliper black £338.30
5F0 073 910 C RH caliper black £338.30
N 910 849 01 Caliper bolts 4 @ £2.50
8J0 615 301 F Brake disc 2 @ £137.95
8J0 698 151 K Brake pads £244.50
000 071 643A Pad sensor not available yet
5F0 073 911 LH backing plate £120.95
5F0 073 911 A RH backing plate £120.95
WHT 005 227 Backing plate screw 6 @ 20p
5F0 073 912 Brake flexi hose 2 @ £85.35
8J0 611 841 D LH flexi bracket £26
GrahamFR
Now AMG Powered
Dec 10, 2008
4,235
Barnsley or Burton
Andrew did you buy yours as a kit? If so where from?
I think they are brembos.
If it was me, id either fork out for the vwr ones or if they were too much id get the alcon ones from revo.
https://www.revotechnik.com/product...55-x-28mm-mono4-big-brake-kit-for-mqb-chassis
and if you really wanna push the boat out you can spend about 3k on the APR brembo ones http://www.goapr.co.uk/products/brembo.html
that's a tuning upgrades you can buy for that price tho, id rather buy a bigger turbo tbh :)
Nobziller
161
Yer very true, I don't have a massive problem with the standard brakes, just think they need better pads, and lines, but kinda want the bigger brakes
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
Would these fit under the standard wheels though? I had a nose at a Cupra in the dealers recently, it had the sub 8 pack fitted, and the caliper sits VERY close to the fitted rims..... :D
Pestonio
21
Thanks everyone for your help; definitely some interesting options for me to look at!
Prices rack up pretty quick so I was thinking I might upgrade bit by bit?
Braided lines and new pads first, then maybe slotted+/drilled rotors, see how that feels before I dive into new calipers.
Anyone know a decent place to get braided lines? Would I be right in guessing lines marketed for Mk2 would fit Mk3?
