Do you mean where the road sign comes up on the mini display? If so, i think you can do this if you have the lane assist camera.
Exactly.. Mine has all The options ticked, so ive lane assist.Do you mean where the road sign comes up on the mini display? If so, i think you can do this if you have the lane assist camera.
And what the hell is a Joker Button?
Hey guys,
I'm being thick!
How do you flip the image from the reverse camera (mines upside down).
I know you can do it, I just can't remember how.
If this is one you fitted yourself there are normally some links you need to cut to inverse the image.
I don't think you can do it in the head unit.
Well I'd obviously do people favours off of this forum... But for ones wider afield (and other makes etc) I might have asked for a beer token or two. Sorry didn't mean to come across all money grabby. I don't know if I'd personally get 300 Quid's worth of use out of it myself tbh. So..
Also people who I have asked for the use of their vcds on here in the past wanted 20-30 quid for it from memory so assumed it was standard practice.
How do you know what tweaks do what? Are there options which are described as such or is it all like hex codes which you have to know specifically which bit to change etc?
You can get crack copies on ebay for less than £20.00.
A little bit of both.
The forums and rosstech support are very helpful
VCDS itself is quite intuitive - you have various modules labelled for different car areas - and in each area - drop down menus.
i've downloaded what i assumed is a hooky copy of it, but unless you have the proper cable its no use! it sees i have a cable plugged in, just it tells me it isn't a rosstech one.
Cable & cd came from China at £16.69. I have no problems with it.
