SEAT PORTABLE SYSTEM [GARMIN] Skins & Hacking
robomrburns
82
Little Teaser
to do:
:funk::funk:
robomrburns
82
Does anyone know how to enable the other skins like the skoda and vw or is that impossible
back on navigon you were able to.
Try this :
create a file:
\VwBrandDevice\Settings\UserSettingsDevMode.default with notepad
with contents:
Code:
<?xml version='1.0' encoding='iso-8859-1'?>
<Settings>
	<Active>1</Active>
</Settings>
make sure it's .default
the create a file called branddevice.reg and put it to the root /.
reboot and then you maybe able to manually chose your brand/skin and unlock the think blue trainer. (All settings (route profiles, last targets...) will be lost)
if not I need to modify the branddevice.exe...
please report back
lucasw21
9
Says something about the vin missing when I put the reg file in the root? (NAVIGON E:)
robomrburns
82
Idea no. 2: lets try an old vwbranddevice from navigon.. I have that exe, but at home. I wont be there until easter, so maybe someone else can send it to you...
robomrburns
82
ok I only know a friend with a Cupra with navigon but like I say that's a cupra
It doesnt matter if its a cupra, fr, skoda or vw. All are the same. All have the same software. Only on first boot skins are changed and functions enabled. So that will work
dps5pt
Happened upon this site a few weeks ago, when looking for something to customize the Seat Entertainment unit - much appreciation to all contributors and looking forward to trying the skin and mod tool from robomrburns.
One query I had on what I think is the upgraded performance exe was the Gforce feature. Does that work on the MK5 Ibiza FR or is the sensor for that section not on the FR?
robomrburns
82
Hi, I enabled the Performance Display for 7.16.8
unfortunately the new Eco-Trip Menu does not show up.
DOWNLOAD
Maybe Phers version will be able to do both! :)
