Hmmm. Excellent write-up!
Now if someone could shed some light on my
problem: 2007
Ibiza 2.0 Sport with Alana HU (non-MP3)
So I pulled the standard HU out and replaced it with a OEM Gamma (with MP3) unit from a 2006 Polo GTi (9N3). (This HU also comes with a 6CD changer and both were working perfectly before I removed it from the donor vehicle)
Problem is that the new HU does not respond at all:
1. Lighting works
2. Flashing red LED present (next to CD slot)
3. Pressing CD LOAD/EJECT buttons produce the right sounds
4. No display whatsoever: No SAFE / 1000 / LEARN (so I cannot enter the security code!)
5. I've tried various button combinations (eg: TP & SCAN and SEEK>> & SCAN) with absolutely no luck
6. I've left the key in the ignition for 1+ hours (red LED stops flashing)
7. I've checked all the fuses (and removed the HU fuse for 5 minutes before putting it back)
Strangely the CD shuttle works perfectly when I connect it to the Alana HU - it's a straight plug-in. (The only requirement is that I still have to tap a wire off the lighting circuit for the shuttle's illumination)
Any
help appreciated!
I HATE giving up!
