You only need a straight screwdriver, there's a slot for it in the bolt.
Hi, great mod !!! Only issue I have is that on both sides of mine the plastic washer came away and fell down into the body structure - doh !! I've tried Seat and it does not show on the rear lamp exploded view - does anyone know the part number for this or where I can source an equivalent ?
Thanks in advance.
Those things seriously don't want to come off! When you pull the light cluster away from the car, are you pulling toward the back of the car or the side of the car? I'm a little confused as the pictures don't clearly indicate what direction the lugs are in.
Anyone got any further tips? I literally feel like it's not meant to come off!
The lugs push into the side of the wing. Don't wiggle the light around from the back of the car or you will snap the lugs, trust me, I know.
Standing facing the car as in the picture, you need to pull on the edge of the light nearest to the filler flap. You need to pull towards you.
It's quite tight but will come out.
Just make sure you have removed the bolt from inside the boot first
Thanks mate! That's where I was going wrong then - I thought it pulled out from the rear of the car and not to the side. Having said that, it still looks awkward
EDIT: Just wondering, is it possible to push the light out from inside the boot? Thinking it goes out in that direction, can it be pushed through the hole where the bolt is removed?
No the bolt hole is quite small iirc and the rest of the inner boot is double skinned.
Once you release the lugs on the side, the light will slide out towards the rear of the car.
There is not much to grab onto the light when releasing the lugs but it does work with fingers.
You can use something to gently pry it away but you would have to be very careful not to scratch the paint.
Trim removal tool should work or a screwdriver wrapped in a microfibre to get you started, just enough to get you're fingers behind the edge of the light
