Love the centre lock wheels, especially the pic of the mahooosive brakes shining through
Hi buddy, your more then welcome to come and spy
The 15mm engine spacers were fitted yesterday, everything seems to be ok but the driveshaft is so close to the chassis I think I'll need to notch it. The only problem I had was the engine cover touching the strut brace but this was easily sorted. It is the mk4 kit I used and I would say 15mm is ok but 20 would cause problems.
Rear discs will be really big if I have my way, going to see what the biggest disc I can fit in the caliper is then go from there.
I'm really looking forward to show and glow, over the moon to have been accepted for a inside position, just a shame I didn't have more notice so I could have done a few little bits of paintwork.
As for air ride ... I'll have to see if I can put in a PPI claim or something
thats mine with a 312..
theres not much room
James your welcome round when ever you like mate.
The plan is to run a 356x28 but I need to check a few things first.
Today the front grilles were painted satin black, looks a lot better in my opinion.
Next job is to replace the door pillar vinyl decals with some 4d carbon ones, all the little things that add up ...
Were hopefully going to look at bringing the front down using some different top mounts before the weekend, fingers crossed.
Haha! I did want 362's but I can't find them in a 28mm thickness.
I've got polo top mounts and spring cups. I've read a few story's about the polo cups being to small so I'm going to make them a bit bigger in diameter.
I've already got the 4d stuff. I didn't even realise you could get 5d!
I think the black plastics will look great against the yellow! It was to much grey on my car. I did the grille to but I'm not sure if I've gone a bit to far.
