The Definitive LED Bulb Replacement Parts Guide
metomurti
123
thats what i thought ,as it is like that on the reversing light but different on the fog light when you push the clips together and take the bulb carrier away there is only 1 bulb which is a long thin one which i take it to be rear light thats the only one
I gave the answer you need above. Answer is clear. What information do you need more?
ToroNegro
142
The Black Country
Take the one you're referring to out and put your lights on, may find you have a different bulb fitment.
Seems unlikely that your means of accessing the bulb would be different.
smurf123
318
swindon wiltshire
hi toro i think im looking at it wrong as according to the manual the fog light is H21W and reversing light is P21WLL the fog light on ebay is long which i have i purchased 2 reversing led bulbs as a previous thread said but the one on mine is different have to find someone that sells h21w led bulb
smurf123
318
swindon wiltshire
i took it the long bulb in there was the rear light not the fog light as if you look ar previous thread he says the fog is the same as the reverse this is what threw me i will noe purchase BAX9S THANK YOU
ToroNegro
142
The Black Country
did fit one of these today 2 x Error Free Canbus 9 SMD LED 501 T10 W5W which toronegro recommended for boot absolutly great they are brighter than the 3 led ones,i believe andy wanted brighter ones try these well impressed
http://partsulike.co.uk/index.php?ma...roducts_id=261
They're great aren't they :) nice and clear too.
What model designation is your car? SE, FR etc and SC, ST or 5 door and I'll update the list.
Also will try and do a proper tutorial tomorrow.
JBB
47
Cornwall
A correction to my previous post for leds for the 5 door SE. The festoon bulb for the vanity mirrors was 39mm not 36mm. But by gently bending the bulb holder the 36 fit. Now all the internal lights are LEDs and what a difference it has made.
Del80y
58
Essex
Toro
I got all parts as listed
But my Mk3 FR SC184 is not the same
Sun visor bulbs are festoons not 501's
and the reverse / fog lamps are 2 different types not the same
Reverse light fits as per list but fog lamp I beleve is BAX9S base type
Del80y
58
Essex
I asked the seller of this bulb if it is canbus or not. He said that it has not got canbus system. So I do not recommend this bulb to you. We have to use canbus bulbs
These are only 6w as well
just checked and mine is H21W
which is going to be a BAY9S not BAX fitting type
lots on ebay with canbus
it wont let me post link as not @15post's yet
metomurti
123
You are right. BAY9S lamps are used in our cars. They are also known as H21W. There are lots of the kind of leds at Ebay. But as I experienced before the best configuration for these type of outer lamps is:
1) Must be cree led
2) Alimunium heat cover with reflection cups
3) Canbus sysytem
4) Refractive index optical lens
For example I bought this lamp for reverse light. It is perfect. Now I am trying to find these kind of bulbs for rear fog light.
http://www.aliexpress.com/item/Hot-...1W-BA15S-LED-Backup-Light-12V/1063943732.html
smurf123
318
swindon wiltshire
found these on ebay £7.49 for 2. Can replace any stock BAY9S/H21W/64136 bulb in your car.
2pcs BAY9S H21W 64136 9 Power LED (Xenon White) Bulbs2pcs BAY9S H21W 64136 9 Power LED (Xenon White) Bulbs dont know if these are any good ,most on ebay when you put model 2013 seat leon it says they wont fit
metomurti
123
Any link?
smurf123
318
swindon wiltshire
or these from hq auto lighting on ebay
H21W BAY9s 433D Xenon LED 8-SMD CREE CanBus ERROR FREE Car Bulbs WHITE ALFA AUDIH21W BAY9s 433D Xenon LED 8-SMD CREE CanBus ERROR FREE Car Bulbs WHITE ALFA AUDI
but says it will not fit our cars yet fits 2012
audi shttp://www.ebay.co.uk/itm/H21W-BAY9s-433D-Xenon-LED-8-SMD-CREE-CanBus-ERROR-FREE-Car-Bulbs-WHITE-ALFA-AUDI-/141191988703?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20dfb2c5df
Del80y
58
Essex
Any link?
Dont have a link to those but try this one
ebay Item number 141191988703
2 bulbs set (a pair)
Colour: Cool White
Direct replacement for a standard H21W BAY9s 433D bulbs
Use mainly for fog, indicator and reverse lamps
Brightness Efficiency: 210 LM
Operating Voltage: 12V
Total length: 39mm
IMPORTANT!! These bulbs have already built in resistors and are compatible with "bulb failure" Can-Bus System in 90% of cars , But some modern cars ECU-s can be very picky and you may need to fit extra resistors to eliminate on dashboard computer error message.
