I'll nip out and try and video it now.
Cheers buddy
Sent from my iPad using Tapatalk HD
Cheers buddy
Didn't quite link properly but copying the link into a browser works fine looks good to me! Just got to find one now lol
Thanks for your help! You should do the red led footwell mod lol
Yer 40's would prob rub on a 9.5J, think about it thou a slightly stretched tyre on the rear is not under as much load as you think, the cars FWD so most of the cornering force is being pushed through the front tyre walls the rears are just following the front BUT are under far less stress on the bead as there following the line of the front BUT without the torque and twist levels which are been applied to the front walls...the chris cross wire pattern that's built into the side walls is designed to withstand a lot of stretch and twisting otherwise they'd just split under hard cornering..
My 2pence worth over with........
Sent a couple more interior bits off for flocking
Went over to Huddersfield for a bit of breakfast and banter with some other fellow SCN members.
A good morning was had by all
Popped over to Majorca for a couple of days to see my family. Saw this while I was there...
10 points for anyone who can guess where it is
Also, just driven back from Leeds Bradford airport, 53 miles. Averaged this:
