He's got the DP ain't he? Looks like a track slag DP in the pic
Need to use LCR injector seals.
Mani
Oil and coolant lines
K04 turbo support bracket
Blanking bung for the EGT sensor
MAF housing
Tip
You may need to modify the abs Pump bracket and brake lines
And modify the gear linkage route and bracket
Modify the coolant hoses from the secondary water pump to turbo
Modify the main metal coolant hose (front of block)
Modify the coolant hoses to the heater matrix and maybe to the expansion tank
Fuel Pump
Spark plugs
Mapping
Think that's most of it. Lol
Mani
MAF housing
Tip
Fuel Pump
Spark plugs
Mapping
