He's got the DP ain't he? Looks like a track slag DP in the pic
Need to use LCR injector seals.
Mani
Oil and coolant lines
K04 turbo support bracket
Blanking bung for the EGT sensor
MAF housing
Tip
You may need to modify the abs Pump bracket and brake lines
And modify the gear linkage route and bracket
Modify the coolant hoses from the secondary water pump to turbo
Modify the main metal coolant hose (front of block)
Modify the coolant hoses to the heater matrix and maybe to the expansion tank
Fuel Pump
Spark plugs
Mapping
Think that's most of it. Lol
all in good time though, cracking little car though right now. enjoying the car so much !
Got some more work done today, very productive !
All wheels arches cleaned, degreased, detailed, dried off & protected.
All four wheels cleaned inside & out using a strong wheel cleaner to removed as much as stubborn grime as possible.
Brakes calipers cleaned & protected.
Cleaned the engine bay again & all surfaces cleaned & protected.
Vehicle was then washed & detailed only on the outside though, ran out of day light !
Lots of tea has been consumed, delicious bacon sandwich & birds tweeting in the background.
Pictures to follow, the joy of photobucket I'll get uploading now.
See you soon guys . . .
Lunch time stop !
Hope you're all having a lovely weekend, take care lady's & gentleman.
love your car always had a soft spot for the mk3 especially in blue and yours looks like a minter and is getting better too.
Thank you, all in good time. Interior will be cleaned today providing this sun stays !
I'm getting there bud, just home from another 4hr operation. Started to separate my fingers.
Really nice to see your car progressing nicely. Got me motivated to finish mine asap and get back on the road once i can drive.
Phil
Always here for a chat if that cheers you up, you've got my number. Thinking about yourself & the road to recovery !
