With winter on it's way I decided to raise the front ride height a bit, it does look good low but it ruins the fun of driving the car, I tend do quite a bit of fast country road driving for fun at the weekend's and with the car being so low the under tray has been rubbing the road quite a lot.
Low ride height (shows) front 63cm Rear 65cm
New ride height (Winter) Front 64.5cm Rear 65cm
I wanted the raise the front a bit more but the off side adjuster for some reason wouldnt turn any higher, the thread probably needs cleaning up a bit, I'll see how it drives now and maybe raise it a bit more.
Whist I had it in the air I decided to take the wheels off and give them a proper clean and seal them up for winter
Before, the rears were much cleaner than the fronts
Autobrite direct Purple rain doing it's thing.
After, waxed with WheelWax and just make sure they were completely covered I sealed them with Werkstat Jett seleant
The brakes and arches also got the same treatment
I have been meaning to do this for ages, I was going to remove the rear disc splash guards and respray them but I thought as I had the polish and wax out I'd try polishing them first
I'm pretty happy with the results so
I'm going to see how it performs with the new ride height and probably order the rear axle centering plates soon
