Before I get started, I've had a search of this forum and others, and have read of many different ways to bleed the coolant system. What I'm trying to find out, however, is how I specifically clear an air lock in the rad. My fans don't come on at the right temp (despite new thermoswitcH) and I've read another thread on here where people found it was due to an airlock in the rad.
They seemed to approach the issue in a couple of different ways. One guy "filled rad from top hose", and another did the following:
"I put the car up on a slope so the front right (rght hand drive offside) was definately the highest point (and at a nice slopey angle, to encourage any bubbles in the rad to move), and bled the system including squeezing the pipes, and revving the car to 3000rpm, until the CTS on VAGCOM reported about 93 DegC (and the coolant was starting to steam). I then put the cap back on and went for a high rpm thrash, including putting the heater on max temp and fan".
Which method should I take? I'm temped to take the following approach:
- start with an already reasonably warm car
- jack up the car on the drivers side front, so that the reservoir is elevated
- take the reservoir cap off
- start engine and let it get up to temp
- squeeze pipes - at the moment I'm not sure which ones I'm meant to squeeze...
- increase revs for a couple of minutes (2000rpm enough?)
- top up as necessary, squeeze pipes again
- turn off engine
- do I:
1 let the car cool before fitting res cap back on, or do I
2 fit the cap back on, take car for a spirited drive, park it, engine off, remove cap and leave to cool, or
3 simply leave to cool before refitting cap, then take for a drive another day.
any advice much appreciated! I've only bled a coolant system once before (not on the leon) and just ran the engine with the rad cap off, and topped up coolant at the rad (bit messy but it worked....)
- turn off engine
- do I:
