Recommend a new Head Unit
Memme112
15
A question in this subject... I have looked at one of these from china. Will it show Seat if I plug it in in my Seat Leon FR 2007? Will it drain battery?
Will i show seat as logo?If not can I change it?
J400uk
1,978
London, UK
Logo seems to vary, some people have found its shown and others get VW. I'm not sure what makes it decide. Battery drain occurs on pre-07 Leons from what I've read, you'll need to find out what CAN gateway yours has as I believe that is the offending part.
Hey buddy I know I got this from the ancient times but just wanted to check that the unit you got fitted is still going strong? I only need the access to put a sub in and connect my ipod to the screen...
Sent from my HTC One X using Tapatalk 4 Beta
Hey there, I actually went with an RNS 310 in the end so a bit different to the one pictured (that was from google). Works fine though and was easy to install.
Recommend reading this guide - http://www.seatcupra.net/forums/showthread.php?t=139255
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,874
7
Middlesbrough
Interested in one of those copied units if they are as good as other people say. Thier ebay adverts do also state they have Samsung parts in the unit, which can only be a good thing?
If anyone has one would they be able to stick a video up of theirs in use?
Also are these easy to fit? Like plug and play or is it a case of removing stuff to locate the gps sensor etc?
J400uk
1,978
London, UK
Video here of the copied nav unit, I'm not a fan myself but each to there own - https://www.youtube.com/watch?v=4Drzzrl6lfU&feature=youtube_gdata_player
In terms of fitting they are easy enough. Follow the guide here http://www.seatcupra.net/forums/showthread.php?t=139255
GPS antenna can be stuck behind the air vents, that's where I put mine and it seems to work ok
mrbubba
463
Very easy to fit and yes mine has Samsung bits inside.
The video posted above seems to be the newer version, it looks quite nice and they've improved most of the menus.
After my experience I would certainly buy another one, bang for buck you can't beat them.
Sent from my GT-I9300 using Tapatalk 2
