Have some time off work so obviously this meant tinkering time with the car....
First job was to replace the small dogbone bush... instructions are supplied so won't bother with the detail so pics should do
There was an increase in vibration on idle but this has settled now... with VT road mounts, a yellow bush and now this bush there is of course going to be increased vibrations and engine noise... its the price of power or at least effective use of power... but when cruising there is nothing really noticeable and thats fine with me...
Next job was to run the hose for the WMI... interior apart... again!...
...drilled a smaller hole next to the one that the opposite side of the pollen filter...
...getting busy in the cable trunking...
Not fitted the pump yet as I need to run the wires and work out which side of the battery to fit it... that will come later as will fitting the nozzle which I have decided will go initially in the FMIC outlet... I am looking at using a dual nozzle system as have seen one of these work rather well... I may even look at staging delivery too...
Next I polished the headlights again as they were showing signs of going a bit yellow again... this time however I have bought some Lamin-x to act as a UV shield... also had some LED sidelights from Trups to fit...
...after a couple of passes with the DA...
Applying the Lamin-x..
...and done ready for trimming...
Refitted..
...and next the passenger side
LED sidelights...
...old 'blue' bulbs...
Next job... new scuttle...
...TT fan washer jets...
TT washers require a little work to fit... hole needs widening and lengthening...
...the hose fitting is a different angle to S3 ones...
...so a hot air gun, careful heating and a 3mm drill....
..extended the wiring on one of the jets...
Fitted it on and wow... well impressed with the way they get fluid on the screen... great upgrade... will try and get a vid of them working tomorrow...
Next job was to start the wiring for the WMI pump and the inline fuel pump as I am rewiring that to run from a relay... bought a 2-way fuse holder so I could sort easy access to the fuses in case the pump one went, that way I don't need to remove half the dash to sort it... removed the lower drivers side dash panel...
Marked up and cut a hole for the fuse box and mounted this in the back of the little cubby...
...also fitted a switch so I could 'arm' the WMI as and when I needed too...
...and the finished article...
Rest of the wiring to do next and hooking up of the pressure switch for the WMI...
<tuffty/>
