Brake bleeding sequence
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
I have new rear discs and pads,front yellow stuff pads and braided lines for my Leon.
I fitted my rear (brembo)discs/pads and rear hoses and I am hoping to fit my front setup tomorrow and bleed it all through with ATE superblue.
Anyone got any tips on bleeding? Is there a special sequence?
Any help would be great.:D
hyphon12
Daft Member
Jun 7, 2011
1,106
Scottish Borders
I'd only use a proper pressure bleeder, too many stories of people having failed servo servo seals when you manually bleed by the brake pedal.
Mk1 banana
334
(Not so) Sunny Hastings
If you can't get hold of one- gravity bleed first, till fluid runs from all bleed nipples (one at a time)
Then manually bleed.
Made in Spain, made better in England;) 223.3hp 263.8lbft
MJ
Public transport abuser
Apr 22, 2008
5,509
13
Manchester
m.facebook.com
Start with the caliper furthest away from master cylinder, which is the nearside rear,
Actually due to the routing of the brake pipes its the o/s/r that has the furthest distance from servo to caliper :whistle:
Always bleed the master cyclinder as loads of people miss this and end up with a poor, verging on dangerous brake pedal.
Oct 17, 2006
1,015
northwest
Depends on model I saw a post a few months back that explained but most are near side rear, also there are 3 nipples in the engine bay the 2 on the reservoir I think the furthest back first. Haha I don't know but I'll be doing it this week
Did you follow any guides for the pipes ? I need to change my caliper and I'm not sure how one would stop the brake fluid falling out?
MJ
Apr 22, 2008
5,509
13
Manchester
m.facebook.com
On any RHD mk4 golf based car the caliper with the longest pipe routing is always the o/s/r as the master cylinder is on the o/s/f, the pipes then run across the bulkhead and under the passenger floor pan, the o/s/r then splits off over the fuel tank, the n/s/r just goes to the axle flexi - so the o/s/r has about 3 more foot of distance to travel.
This is the same for ibizas, arosas, alteas in fact almost any RHD VW group vehicle.
There are 2 bleed nipples associated with the brakes yes, both on the master cyclinder - the other is on the clutch slave cylinder and has no bearing on the brake system at all.
Crack open the bleed nipple on the caliper you're replacing then depress the brake pedal, once depressed use something to hold it down and whilst its held down it will not allow any more fluis through. Or buy a flexi clamp.
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
I did think o/s/r was the longest, how do I bleed the master cyl? Do I need to do the clutch slave as well? How much fluid will I realistically need?
MJ
Apr 22, 2008
5,509
13
Manchester
m.facebook.com
With the pressure bleeder or easy-bleed attached you just crack the back one off then the front, the nipples are only 7/8mm so you need to be careful.
1.5/2.0 litres will be more than enough.
You don't need to bleed the clutch for the sake of the brakes, no.
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
Are they easy enough to get to? I'll leave the clutch be I think. So o/s/r...n/s/r...then fronts then master cyl? Thanks for your help mate.
STU3Y
1,271
Kent
Where are the bleed nipples on the master cylinder for mk2 leon reference sport 2007. From what I can see there doesn't appear to be one.
Sent from my SM-G920F using Tapatalk
STU3Y
1,271
Kent
With regards to bleed sequence for mk2 leon.
Reactions: Woody_72
