Kl man, I always use 99 the LCr comes standard with s3 cooler but I've upgraded. Why does the boost need turned down a notch?
Plastic ended S3 cooler though, not the metal ended one that everybody upgrades to
The reason you HAVE to turn the boost down is your turbo on B9 is working very hard and its blowing hot & with higher timing it will cause you detonation. even B7 T7 F6 will do,,,,you might think you will loose bhp but with higher timing you will keep your bhp but what you will gain is torque figures which you really want. If you want to run higher boost you better of looking at WMI system then you are safe to set B9 T9 F5. with this you should get 420bhp if not more then mins.
Good progress buddy. I really need a wee passenger blast in this mate.
