Help / Advice for fitting an S3 intercooler
Al
7,326
9
Climate here sucks -20oC if we are lucky. While a/c assembly probably weighs 10kg approx
Lee M
Make sure the inside lip of you front bumper doesn't rub on the a/c matrix once its all back together. When I fitted my THS cooler I had issues! Expensive ones.
Aug 1, 2012
582
Riga, Latvia
In my climate zone is wide range of air temperature.
Now its -15 and on summer it will be +20 to +30 deg
I cant remove A/c and loose comfort on summer
n0ble
Newbie
Sep 14, 2006
379
I used the one of the APR guides on a friends car to change the intercooler and also used the original pipework by cutting the metal end off.
Took around 2 hours to complete the job.
Sent from my Galaxy S3 using Tapatalk 2
Aug 1, 2012
582
Riga, Latvia
I did the same with pipes and used clamps
Jun 26, 2008
1,299
Just round the corner.
Really, are you anywhere near Loughborough???
Seriously though, can you remeber what size bolts you used to secure the IC?
Cheers.
n0ble
Newbie
Sep 14, 2006
379
Hi. Sorry I have only just spotted this.
Yes I'm not far away from Loughborough.
I don't remember what size bolts I used, I believe I remember finding the correct size on the golf forums.
Do you still need help with it?
Jun 26, 2008
1,299
Hi Mate,
Still not fitted it, got let down by a mate last weekend. I'm planning on doiung it next weekend (16/17th).
I found some bolts in the box with the intercooler, hopefully there the right ones.
If your free to help that would be smashing.
If your ok with that weekend, I will pm you my details mate, and price mate.
1,299
Fitted the intercooler. Took just under 2 hours to fit. The correct bolts are suppliex with the intercooler. Probably down to air temp. But feels like spooling up faster.
Now ready for stagd 2+
tonto
1,265
plymouth
my FR (tfsi) is currently stage 1! just waiting on hardware to go stg2! im still unsure if im going to benefit from the S3 cooler just yet :/
Feb 16, 2013
1,103
North Wales
would really like this fmic upgrade on mine before an APR remap as its got stage 2 on now
how much would it cost for someone/garage to do the work for me + removing all the aircon etc on a K1
Jun 26, 2008
1,299
I was quoted it's a 4 hour job, which it isn't.
I'd budget paying £70 ish an hour, and be being charged 2 - 2 1/2 hours. Unless you know of local garages to you. It would also be useful being there whilst it's done.
Jun 26, 2008
1,299
My spelling is awful, that's posting while using my phone.
Fitted the intercooler. Took just under 2 hours to fit. The correct bolts are supplied with the intercooler. Probably down to air temp. But feels like the turbo is spooling up faster.
Now ready for APR stage 2+.
Feb 16, 2013
1,103
North Wales
thanks for the info m8
ill save up for the s3 fmic;)
tonto
1,265
plymouth
did you guys use the oem hoses?
im about to buy one from darkside (£250) its another £100 for the hoses :/ i can cut the end off the oem hose and jubilee clip them on right ?
just a thought, can i not go TPS and get a cooler from them? surely it'll be same spec ?
Jun 26, 2008
1,299
Hi mate,
I used the original hoses, but cut the metal connectors that go into the intercooler.
I placed the metal end in a vice, and cut LENGTH ways. The connector is alluminium, so is very easy to cut, just dont go mad otherwise you will the hose.
I made four cuts then just prise the inner/outer parts off the hose.
Hope this helps.
p11lkw
325
Did you get a price from TPS ?
tonto
1,265
plymouth
Hi mate,
Hope this helps.
Oh right wicked man. I thought it was actually cut the hose down not just remove the clip! Cheers.
No mate sorry. I only priced up the injectors, 88 each plus the dreaded. So, 106 each is awesome. I will get a list of everything required for a conversion and price the lot up.the
